はじめに
This guide will walk you through how to replace the front casing on the NetCam.
必要な工具と部品
この手順で使用する道具:Tweezers$4.99
Use tweezers to gently pull out the white attachment from the port.
Use your fingers to pull out the white attachment from the tan port on the front of the board a little.
Carefully use your fingers to gently pull out the white attachment from the tan colored part.
終わりに
