はじめに
This guide will walk you through how to replace the whole circuit board on the NetCam.
必要な工具と部品
Use tweezers to gently pull out the white attachment from the port.
Use your fingers to pull out the white attachment from the tan port on the front of the board a little.
Flip the circuit board to the back side.
Fold down the tape with your finger.
With the Phillips #0 screwdriver, unscrew the two 1.2 mm screws.
ある他の人がこのガイドを完成しました。
