危険
潜在的な危険
この手順に正しく従わない場合は損傷が生じる可能性があります。ご注意のうえ使用し、すべての警告に従ってください。
危険
はじめに
The audio amplification PCB is the PCB which has the task of amplifying the B212D speaker's input signals.
パーツ
パーツは必要ありません。
  1. Unplug your speaker from the power outlet.
    • Unplug your speaker from the power outlet.
    • Remove the 8 Phillips screws from the back of the speaker.
  2. Carefully remove the back panel, lifting out the metal electronics-box with it.
    • Carefully remove the back panel, lifting out the metal electronics-box with it.
    • To avoid damaging your speaker, remove slowly, as there is still a wire attached from the electronics box to the speaker.
  3. There are two silver, 6 mm-long machine screws with two 1/8" inner-diameter washers on the exterior of the metal electronics box; remove these first using a #2 philips screwdriver. There are five of the same type of machine screw (silver, 6 mm-long) remaining around the metal electronics box's exterior; remove these as well. You should have removed a total of 7 machine screws and 2 washers.
    • There are two silver, 6 mm-long machine screws with two 1/8" inner-diameter washers on the exterior of the metal electronics box; remove these first using a #2 philips screwdriver.
    • There are five of the same type of machine screw (silver, 6 mm-long) remaining around the metal electronics box's exterior; remove these as well.
    • You should have removed a total of 7 machine screws and 2 washers.
    • The reason for removing the two screws with the two washers first (or replacing them last when reassembling) is that their holes are actually slots. They are designed as slots to accommodate slop in the assembly, and if unscrewed out of order, you may have difficulty while removing - or possibly even damage - the other five screws.
  4. Remove the portion of the metal housing that you freed with the 7 screws in the previous step.
    • Remove the portion of the metal housing that you freed with the 7 screws in the previous step.
  5. Inside the metal electronics box housing is a white clip attached to a small PCB; remove this. The white clip in this image has been glued, indicating that the manufacturer may not expect  the end user to remove this clip; it is difficult to proceed with the disassembling without doing so, however, because the rest of the speaker does not provide a sufficient surface on which to work. Snake the clip head through the hole in the metal electronics box casing.
    • Inside the metal electronics box housing is a white clip attached to a small PCB; remove this.
    • The white clip in this image has been glued, indicating that the manufacturer may not expect the end user to remove this clip; it is difficult to proceed with the disassembling without doing so, however, because the rest of the speaker does not provide a sufficient surface on which to work.
    • Snake the clip head through the hole in the metal electronics box casing.
  6. Free shipping on all orders over $100 or containing a Pro Tech Toolkit!
    当社のショップを閲覧する
  7. Remove the 4, 7/32" long machine screws with a #2 phillips head screwdriver. Remove the 4, 7/32" long machine screws with a #2 phillips head screwdriver.
    • Remove the 4, 7/32" long machine screws with a #2 phillips head screwdriver.
  8. Rotate the back panel so you can view the interior; note the three wires attached. Remove the wires to you can fully remove the back panel.
    • Rotate the back panel so you can view the interior; note the three wires attached.
    • Remove the wires to you can fully remove the back panel.
  9. Remove the 2 indicated flat head machine screws indicated using a #2 phillips head screwdriver. The small PCB could be removed for replacement at this point, but you can also just leave it attached to the audio amplification PCB as you remove other parts. The small PCB could be removed for replacement at this point, but you can also just leave it attached to the audio amplification PCB as you remove other parts.
    • Remove the 2 indicated flat head machine screws indicated using a #2 phillips head screwdriver.
    • The small PCB could be removed for replacement at this point, but you can also just leave it attached to the audio amplification PCB as you remove other parts.
  10. Remove the 2 indicated flat head machine screws using a #2 phillips head screwdriver. Remove and set aside the metal panel that was separating the small PCB from the audio amplification PCB. Remove and set aside the metal panel that was separating the small PCB from the audio amplification PCB.
    • Remove the 2 indicated flat head machine screws using a #2 phillips head screwdriver.
    • Remove and set aside the metal panel that was separating the small PCB from the audio amplification PCB.
  11. Note the 4 large flat head machine screws which hold the clamps on the opposite side; remove them with a #2 phillips head screwdriver. The clamps are meant to hold the audio amplification PCB's IC's to the common heat sink; they ensure proper contact between the heat sink and the IC's through the ceramic thermal paste.
    • Note the 4 large flat head machine screws which hold the clamps on the opposite side; remove them with a #2 phillips head screwdriver.
    • The clamps are meant to hold the audio amplification PCB's IC's to the common heat sink; they ensure proper contact between the heat sink and the IC's through the ceramic thermal paste.
  12. Note the 3 flat head machine screws holding the heat sink to the metal electronics box; remove them using a #2 phillips head screwdriver. It may be possible to leave this heat sink connected, but you will have to separate the heat sink from the IC's and be careful not to touch the ceramic thermal paste: its really hard to remove, even with soap!
    • Note the 3 flat head machine screws holding the heat sink to the metal electronics box; remove them using a #2 phillips head screwdriver.
    • It may be possible to leave this heat sink connected, but you will have to separate the heat sink from the IC's and be careful not to touch the ceramic thermal paste: its really hard to remove, even with soap!
  13. Note the location of the 4 indicated machine screws which hold the audio amplification PCB to the metal electronics box; remove them using a #2 phillips head screwdriver. The screws are not actually attached in this photo; sorry!
    • Note the location of the 4 indicated machine screws which hold the audio amplification PCB to the metal electronics box; remove them using a #2 phillips head screwdriver.
    • The screws are not actually attached in this photo; sorry!
  14. Remove the audio amplification PCB from the metal electronics box. If you haven't already, remove the heat sink from the IC's, being careful not to get any of the ceramic thermal paste on your skin, as it is difficult to remove, even with soap.
    • Remove the audio amplification PCB from the metal electronics box.
    • If you haven't already, remove the heat sink from the IC's, being careful not to get any of the ceramic thermal paste on your skin, as it is difficult to remove, even with soap.
まとめ
2 の人々がこのガイドを完成させました。
gameslammer7
メンバー登録日: 2012年03月29日
861 ポイント
6のガイドは作成済み
Bonjour a tous
Mais ou trouve t'on les pièces détaché
Cordialement
pmoizan - 返信
lol pareil je cherche la pcb
gotnoidentity35 - 返信
I need the schematic for this unit can you help I have +12v missing +and - 15v
mattox_64@hotmail.com
black - 返信
統計データを表示:
過去 24時間: 3
過去 7 日: 26
過去 30 日: 109
今までの合計 9,498
