メインコンテンツにスキップ
Beboncool Gamepad for Nintendo Switch Charging Port Replacement
必要な工具と部品
  1. Beboncool Gamepad for Nintendo Switch Charging Port Replacement, Charging Port: 手順 1、 3の画像 1 Beboncool Gamepad for Nintendo Switch Charging Port Replacement, Charging Port: 手順 1、 3の画像 2 Beboncool Gamepad for Nintendo Switch Charging Port Replacement, Charging Port: 手順 1、 3の画像 3
    • Use the plastic opening tool to remove the blue plastic grips from the sides of the controller.
  2. Beboncool Gamepad for Nintendo Switch Charging Port Replacement: 手順 2、 2の画像 1 Beboncool Gamepad for Nintendo Switch Charging Port Replacement: 手順 2、 2の画像 2
    • Use the Phillips #0 screwdriver to remove the seven 5mm screws from the back of the controller.
  3. Beboncool Gamepad for Nintendo Switch Charging Port Replacement: 手順 3、 3の画像 1 Beboncool Gamepad for Nintendo Switch Charging Port Replacement: 手順 3、 3の画像 2 Beboncool Gamepad for Nintendo Switch Charging Port Replacement: 手順 3、 3の画像 3
    • Gently separate the two halves of the controller.
    • As the two covers come apart the L1 and R1 button, will fall free from the controller. Be sure not to lose them if they should pop out and fall.
    • Be sure to slide the small circuit boards out of the covers to be able to separate the two halves
  4. Beboncool Gamepad for Nintendo Switch Charging Port Replacement: 手順 4、 2の画像 1 Beboncool Gamepad for Nintendo Switch Charging Port Replacement: 手順 4、 2の画像 2
    • Use the Phillips #0 screwdriver to remove the two 3.5mm screws holding the circuit board in place.
  5. Beboncool Gamepad for Nintendo Switch Charging Port Replacement: 手順 5、 2の画像 1 Beboncool Gamepad for Nintendo Switch Charging Port Replacement: 手順 5、 2の画像 2
    • Lift the motherboard from the back case with the vibration motors and button boards attached.
  6. Beboncool Gamepad for Nintendo Switch Charging Port Replacement: 手順 6、 2の画像 1 Beboncool Gamepad for Nintendo Switch Charging Port Replacement: 手順 6、 2の画像 2
    • Gently pull the battery from the circuit board, leaving it connected to the board with its lead wires.
  7. Beboncool Gamepad for Nintendo Switch Charging Port Replacement: 手順 7、 3の画像 1 Beboncool Gamepad for Nintendo Switch Charging Port Replacement: 手順 7、 3の画像 2 Beboncool Gamepad for Nintendo Switch Charging Port Replacement: 手順 7、 3の画像 3
    • Remove the charging port from the edge of the motherboard by desoldering each of its four solder points and lifting the port from the board.
終わりに
作成者
1人の作成者と共同作成されました。
Riley McCullough
メンバー登録日: 01/30/20
285 ポイント
2のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 17
今までの合計 665
