この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
Use this guide to replace the motherboard on the first generation Beats Studio.
必要な工具と部品
Using the T5 Torx screwdriver, remove the black screws on both sides of the outside of the headband.
4 (2 per side) Torx type T5, 3.5mm long screws.
Use the plastic opening tool to gently pry the black plastic hinge piece directly away from the headband as shown.
Remove the small metal hinges from their housings. There are a total of 4 hinges, two per side of the headphones.
Using a T5 Torx screwdriver, remove the silver screws from the silver segment of the headband.
4 (2 per side) Torx type T5, 4.0mm long screws.
Using the plastic opening tool, gently pry the headband cushion directly away from the plastic portion of the headband as shown. Pry the plastic portion a small amount and then move the opening tool sideways along on the headband. Repeat on both sides until the cushion separates from the top plastic part of the headband.
Carefully remove the metal band from each of the hinge housings on each side. These should come off quite easily, provided that you have removed the hinges as instructed in step 3.
Congratulations, you have completely removed the headband! This will allow for ease of accessibility to the speakers should you choose to delve further into the depths of your headphones.
Pinch the ear cushion between your thumb and forefinger.
Carefully pull the cushion directly away from the earpiece.
Repeat for the other ear cushion.
Use the plastic opening tool to remove the black ring from the speaker. This will allow you to access the screws on the metal ring.
Congratulations, you now have access to the rest of the speaker!
The black lip is located on the back side of the ear cushion.
Make sure you are working on the speaker that has the label "R" for the right ear. This speaker is the one you must disassemble in order to access the motherboard.
Use a 00 Phillips head screwdriver to remove the screws holding down the metal ring.
7 Phillips type 00, 3.9mm long screws.
Set aside the metal ring.
Using the 0 Phillips head screwdriver, remove the 3 screws holding down the red speaker assembly.
3 Phillips type 0, 8.0mm long screws.
The screws removed in the previous step held the cover in place so, go ahead and just lift it out!
Easy as 1-2-3!
Use the 0 Philips screwdriver to remove the two 6.0 mm screws screws that hold the motherboard and cover.
2 Philips type 0, 6.0mm long screws.
Once the screws have been removed from the other side, turn the speaker housing around.
Simply lift the cover with the beats logo off.
Congratulations! You have uncovered the motherboard!!
Locate the black power button switch, then gently remove it with a pair of tweezers.
The mute button
Power switch.
Congratulations, you now have access to the motherboard!
The wires can now be de-soldered and the old motherboard can be replaced with a new one.
Before you begin soldering, make sure to mark or label all of the wires so that you remember exactly where they go.
12 の人々がこのガイドを完成させました。
8 件のコメント
Did you know what is the model or tipe of cable? I need to replace it
I would love to know as well what kind of cable I need to buy.
I mean the one that is multi colored there, very thin.
Where is the Bluetooth Adapter? Is it welded to the mother board? Or is it stand alone with like a flex cable connection? Basically, can the Bluetooth Adapter alone be replaced? Thanks.
There isn’t any Bluetooth. These are WIRED headphones, the model is named “Beats Studio” and these are the FIRST generation.
Do you do beats mixrs electrical wires replacements for the headphones ?
PS MY NAME IS JOEY WILSON and i and 17 teen years old and i was just couries if you can fix the replacement wires for my beats mixrs and they are white and the problems with them are one side works and the other side doesn't work and ut starts to get hot and gets overheat way to easy and they make weird noise so can you please helpme or even tell me what to do to fix my headphones so please send me a response ok thank have a great day .
