メインコンテンツにスキップ
Beats Studio First Generation Headphone Jack Replacement
必要な工具と部品
  1. Beats Studio First Generation Headphone Jack Replacement, Removing the outer headband screws.: 手順 1、 1の画像 1
    • Using the T5 Torx screwdriver, remove the black screws on both sides of the outside of the headband.
    • 4 (2 per side) Torx type T5, 3.5mm long screws.
    not necessary !!
    John Coops - 返信
  2. Beats Studio First Generation Headphone Jack Replacement, Removing the plastic hinge guards.: 手順 2、 2の画像 1 Beats Studio First Generation Headphone Jack Replacement, Removing the plastic hinge guards.: 手順 2、 2の画像 2
    • Use the plastic opening tool to gently pry the black plastic hinge piece directly away from the headband as shown.
    not necessary !!
    John Coops - 返信
    where can i find this piece?
    alex - 返信
  3. Beats Studio First Generation Headphone Jack Replacement, Removing the hinge pins.: 手順 3、 1の画像 1
    • Remove the small metal hinges from their housings. There are a total of 4 hinges, two per side of the headphones.
    • The hinge pins may slide out upon removal of the black hinge piece from the previous step. Be careful not to lose the hinge pins.
    i need to buy one hinge pin for my beats by dre 1.0 studio
    mrfuentescisneros - 返信
    This is DEFINITELY NOT necessary !
    John Coops - 返信
  4. Beats Studio First Generation Headphone Jack Replacement, Removing the metal bands.: 手順 4、 1の画像 1
    • Using a T5 Torx screwdriver, remove the silver screws from the silver segment of the headband.
    • 4 (2 per side) Torx type T5, 4.0mm long screws.
    This step is DEFINITELY NOT necessary !
    John Coops - 返信
  5. Beats Studio First Generation Headphone Jack Replacement, Removing the headband cushion.: 手順 5、 3の画像 1 Beats Studio First Generation Headphone Jack Replacement, Removing the headband cushion.: 手順 5、 3の画像 2 Beats Studio First Generation Headphone Jack Replacement, Removing the headband cushion.: 手順 5、 3の画像 3
    • Using the plastic opening tool, gently pry the headband cushion directly away from the plastic portion of the headband as shown. Pry the plastic portion a small amount and then move the opening tool sideways along on the headband. Repeat on both sides until the cushion separates from the top plastic part of the headband.
    John Coops - 返信
  6. Beats Studio First Generation Headphone Jack Replacement, Removing the metal headband support.: 手順 6、 2の画像 1 Beats Studio First Generation Headphone Jack Replacement, Removing the metal headband support.: 手順 6、 2の画像 2
    • Carefully remove the metal band from each of the hinge housings on each side. These should come off quite easily, provided that you have removed the hinges as instructed in step 3.
    • Congratulations, you have completely removed the headband! This will allow for ease of accessibility to the speakers should you choose to delve further into the depths of your headphones.
    • The black wire connecting the two speakers is somewhat fragile! Check that it isn't frayed. If it is frayed, consider repairing it with some electrical tape, splicing it, or replacing it.
    John Coops - 返信
  7. Beats Studio First Generation Headphone Jack Replacement, Removing the ear cushion.: 手順 7、 3の画像 1 Beats Studio First Generation Headphone Jack Replacement, Removing the ear cushion.: 手順 7、 3の画像 2 Beats Studio First Generation Headphone Jack Replacement, Removing the ear cushion.: 手順 7、 3の画像 3
    • Pinch the ear cushion between your thumb and forefinger.
    • Be very careful when pulling off the ear cushion, as the material holding the cushion onto the plastic ring can rip easily.
    • Carefully pull the cushion directly away from the earpiece.
    • The cushion will have a thin piece of foam inside of it that may fall out upon removal. Make sure to save this for reassembly.
    • Repeat for the other ear cushion.
    i have torn my cuson inside part that helps to hold the out soft part. and i lost it how to do it
    imbd Indian medicine bd - 返信
  8. Beats Studio First Generation Headphone Jack Replacement, Removing the plastic ring.: 手順 8、 3の画像 1 Beats Studio First Generation Headphone Jack Replacement, Removing the plastic ring.: 手順 8、 3の画像 2 Beats Studio First Generation Headphone Jack Replacement, Removing the plastic ring.: 手順 8、 3の画像 3
    • Use the plastic opening tool to remove the black ring from the speaker. This will allow you to access the screws on the metal ring.
    • Congratulations, you now have access to the rest of the speaker!
    • For reassembly, the black ring cannot snap back into the speaker the way it was disassembled. It must first go inside the black lip of the ear cushion. The black lip is located on the back side of the ear cushion. Please refer to the last two pictures on this step.
    • The black lip is located on the back side of the ear cushion.
    Hi does this work for the beats studio wireless?
    Jack - 返信
    I bought the parts two (2) ear cushions and a head band replacement on eBay for about $10 USD
    the process described here works well if the ear pad is old and you do not mind destroying the old one to gain access - however you will destroy the ear cushion pad assembly to separate it from the headphones - so be prepared to buy replacement cushion assemblies - when you disassemble you cannot re-install the original cushions
    the disassembly process tears the plastic cover that goes around the ear cushion plastic ring
    Legacy Finance Group - 返信
  9. Beats Studio First Generation Headphone Jack Replacement, Removing the metal ring.: 手順 9、 1の画像 1
    • Use a 00 Phillips head scewdriver to remove the screws holding down the metal ring.
    • Set aside the metal ring.
    • 7 Phillips type 00, 3.9mm long screws.
    John Coops - 返信
  10. Beats Studio First Generation Headphone Jack Replacement, Removing the speaker assembly.: 手順 10、 1の画像 1
    • Using the 0 Phillips head screwdriver, remove the 3 screws holding down the red speaker assembly.
    • 3 Phillips type 0, 8.0mm long screws.
  11. Beats Studio First Generation Headphone Jack Replacement, Remove the PCB screw.: 手順 11、 1の画像 1
    • Use the 00 screwdriver to remove the screw holding down the headphone jack PCB board.
    • 1 Phillips type 00, 5.0mm long screw.
  12. Beats Studio First Generation Headphone Jack Replacement, Removing the headphone jack assembly.: 手順 12、 2の画像 1 Beats Studio First Generation Headphone Jack Replacement, Removing the headphone jack assembly.: 手順 12、 2の画像 2
    • Use a plastic opening tool to gently pry the headphone jack and board up and out as shown.
    • Inspect the wires and ensure that they are all appropriately attached and not shorted or frayed.
    • If necessary, the board can be de-soldered and replaced with a new jack and board assembly.
    i have disconnected 8 wires mistakenly, 4 left speakers and mic, 2power cable and 2 wires from right side, how can i attracted them? please help to get the diagram.
    tushar_rocks08 - 返信
    It said replacing the headphone jack. You should have said replacing the female jack. I have a pair of beats audio headphones but they have a male plug at the end . Not a female at the headphones. But my scull candy headphones do. And I have had to repair the jack. But never had to take them apart like your showing
    Nancy - 返信
    All of this person’s guides are stupid. Only steps 7 8 10 11 and 12 are required. Steps 1-6 are totally unnecessary, and there is absolutely NO need to remove the metal ring in step 9.
    John Coops - 返信
終わりに
13 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Garrett Reed
メンバー登録日: 04/15/14
1,598 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team 9-18, Regan Spring 2014 Cal Poly, Team 9-18, Regan Spring 2014人のメンバー
CPSU-REGAN-S14S9G18
4 メンバー
11のガイドは作成済み
11 件のコメント
Hi!
Could you please tell me where to get a replacement for the headphone jack (and board assembly)? I cannot find it anywhere.
Thanks a lot!!
Simon - 返信
These instructions are ridiculously over complicated! You can completely skip steps 1-6. You can also skip step 9 (no need to remove the metal ring). On my son's set the soldering job was sloppy and the wires had shorted causing the left side to stop working. I very gently lifted, separated, bent and repositioned the wires and it worked. But what you should actually do if you have ANY sense is to not buy this pile of overpriced plastic crap to begin with. My 30 yr old Sony MDR-V600's sound better, dont need batteries, and aren't falling apart.
alpinchisholm - 返信
Totally agreed. This person’s guides all show the unnecessary steps 1-6 and 9 which are definitely not needed.
John Coops -
Me gustaría que me proporcionarán el diagrama o como van conectados los cables ya que se me de soltaron y no se como van gracias
tripleseven13 - 返信
Where I can find pinouts for headphone jack and motherboard? I have 3 wires teared off the jack pcb.
And I have different wire colors. The one on top (step 12) is gold-red and yours is green.
Thanks.
A Sh - 返信
beats by dr. dre cable contain plz
murad ali - 返信
Hello!
Any one knows where I can buy this kind of cable?
Thanks
gonzaloefl - 返信
I have Beats Studio 3. Will be thankful if someone helps in wiring diagram with colors. I searched a lot but couldn't find it.
Regards
Dilbar Khan - 返信
sir i have tried to fix one wire and ends up with losing more 5wire.and due to be a bad solder can anyone help me please with the wiring diagram i can understand wich wire where to solder. please helpme with that
same issue
cant find
dr Stephen strange -
hey can anybody help me to give this headphone jack to all wiring diagram i have make 6/7 disconnected/\ tnx
dr Stephen strange - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 9
過去 30 日: 61
今までの合計 30,851
