メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Beats Studio First Generation Headband Replacement
必要な工具と部品
  1. Beats Studio First Generation Headband Replacement, Removing the outer headband screws.: 手順 1、 1の画像 1
    • Using the T5 Torx screwdriver, remove the black screws on both sides of the outside of the headband.
    • 4 (2 per side) Torx type T5, 3.5mm long screws.
    FixBotに聞いてみる
    コメントを追加
  2. Beats Studio First Generation Headband Replacement, Removing the plastic hinge guards.: 手順 2、 2の画像 1 Beats Studio First Generation Headband Replacement, Removing the plastic hinge guards.: 手順 2、 2の画像 2
    • Use the plastic opening tool to gently pry the black plastic hinge piece directly away from the headband as shown.
    FixBotに聞いてみる
    コメントを追加
  3. Beats Studio First Generation Headband Replacement, Removing the hinge pins.: 手順 3、 1の画像 1
    • Remove the small metal hinges from their housings. There are a total of 4 hinges, two per side of the headphones.
    • The hinge pins may slide out upon removal of the black hinge piece from the previous step. Be careful not to lose the hinge pins.
    FixBotに聞いてみる
    コメントを追加
  4. Beats Studio First Generation Headband Replacement, Removing the metal bands.: 手順 4、 1の画像 1
    • Using a T5 Torx screwdriver, remove the silver screws from the silver segment of the headband.
    • 4 (2 per side) Torx type T5, 4.0mm long screws.
    FixBotに聞いてみる
    コメントを追加
  5. Beats Studio First Generation Headband Replacement, Removing the headband cushion.: 手順 5、 3の画像 1 Beats Studio First Generation Headband Replacement, Removing the headband cushion.: 手順 5、 3の画像 2 Beats Studio First Generation Headband Replacement, Removing the headband cushion.: 手順 5、 3の画像 3
    • Using the plastic opening tool, gently pry the headband cushion directly away from the plastic portion of the headband as shown. Pry the plastic portion a small amount and then move the opening tool sideways along on the headband. Repeat on both sides until the cushion separates from the top plastic part of the headband.
    FixBotに聞いてみる
    コメントを追加
  6. Beats Studio First Generation Headband Replacement, Removing the metal headband support.: 手順 6、 2の画像 1 Beats Studio First Generation Headband Replacement, Removing the metal headband support.: 手順 6、 2の画像 2
    • Carefully remove the metal band from each of the hinge housings on each side. These should come off quite easily, provided that you have removed the hinges as instructed in step 3.
    • Congratulations, you have completely removed the headband! This will allow for ease of accessibility to the speakers should you choose to delve further into the depths of your headphones.
    • The black wire connecting the two speakers is somewhat fragile! Check that it isn't frayed. If it is frayed, consider repairing it with some electrical tape, splicing it, or replacing it.
    FixBotに聞いてみる
    コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
20 の人々がこのガイドを完成させました。
作成者
6人の作成者と共同で作成されました。
Anand Mangal
メンバー登録日: 04/15/14
1,101 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team 9-18, Regan Spring 2014 Cal Poly, Team 9-18, Regan Spring 2014人のメンバー
CPSU-REGAN-S14S9G18
4 メンバー
19のガイドは作成済み
2件のガイドコメント
where can i buy the pin for the hinge i woud like you know email the link to this email drkimaging@gmail.com
derek - 返信 共有
When replacing the headband there is no need to remove any screws or hinges for the beats studio 1.0 as described here.
Simply carefully remove the headband cushion by snapping it out from the frame as it is merely a push fir and not reattained at the two ends it is just push fit into the top plastic section. Just tease it out gently with small screwdriver and then the the replacement in place and listen to the click as it snaps in. Simple and easy takes less than a minute.
Roger Holland - 返信 共有
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 24
過去 30 日: 120
今までの合計 82,770
