メインコンテンツにスキップ
Beats Solo HD Speaker Replacement
必要な工具と部品
  1. Beats Solo HD Speaker Replacement, Remove the foam pads from both the left and right speakers.: 手順 1、 2の画像 1 Beats Solo HD Speaker Replacement, Remove the foam pads from both the left and right speakers.: 手順 1、 2の画像 2
    • Remove the foam pads by twisting them counterclockwise.
    • The pads should release from the grooves that are housed on the speaker inside.
  2. Beats Solo HD Speaker Replacement, Unscrew the speakers from the housing: 手順 2、 2の画像 1 Beats Solo HD Speaker Replacement, Unscrew the speakers from the housing: 手順 2、 2の画像 2
    • There should be approximately three screws holding the right speaker. Unscrew them to gain access to the wiring of the speakers.
    • Keep the screws in a safe place. They are small and can easily be lost.
    Plus, be careful because of the magnet in the speaker. You need to hold back the screws when they are unscrewed. Otherwise they might damage the membrane.
    Rufus bernstein - 返信
  3. Beats Solo HD Speaker Replacement, Desolder the connections to the speaker: 手順 3、 2の画像 1 Beats Solo HD Speaker Replacement, Desolder the connections to the speaker: 手順 3、 2の画像 2
    • Using safety gloves, desolder the two wires of the speaker.
    • Leave the desoldered and unstripped wires for the next step.
  4. Beats Solo HD Speaker Replacement, Repeat steps in reverse to re-assemble: 手順 4、 1の画像 1
    • Follow the instructions in reverse to put together the speaker in the housing, as well as the foam pad over the speaker.
    • Solder the new speaker to the two wires of the headphones.
    • Make sure to pack in all of the companents back into the housing when finished with this step.
    Mooie handleiding, dank je!
    Hebben jullie echter ook een url voor het bestellen van een vervangende speaker voor een Solo?
    Great manual, thanks.
    Do you also have a url to order a replacement Solo speaker?
    Thxs,
    Jeroen
    jlangestraat - 返信
  5. Beats Solo HD Speaker Replacement, Repeat steps for left speaker: 手順 5、 1の画像 1
    • If you need to repair the left speaker, there may be an additional step you need to take to replace the speakers. This takes the audio jack into account.
終わりに
8 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
redacted
メンバー登録日: 10/11/14
544 ポイント
1ガイドが承認済み
チーム
USF Tampa, Team 1-1, Donnelly Fall 2014 USF Tampa, Team 1-1, Donnelly Fall 2014人のメンバー
USFT-DONNELLY-F14S1G1
1 メンバー
2のガイドは作成済み
3 件のコメント
Hello. I also have 1 damaged Monster Beats Solo. It was bought in 2013. The right speaker does not working properly - it sounds softer (opposite of lourder) than the left speaker and whenever I move, I can feel the sound of something loose inside the right ear cup/speaker. I already found some sellers selling the replacement speakers on ebay. Before buying the replacement parts, I decided to open the ear cup myself to check whether it is easy to open or not. However, so far I am unable to open it. I avoind using too much force because it is afraid that I might break the headphone.
SHAMSUL FAISAL MOHD HUSSEIN - 返信
According to some websites, the twist counter clockwise removal of the headphone pad is indicative of a fake beats solo HD, the genuine ones have fixed pads apparently. I can't guarantee this, but I do have a set of solo HDs with a faulty speaker and I can't easily remove the pad either
Simon16a - 返信
you forgot to mention polarity which matters if you mess that up ull get a lack of bass and phasing issues positive and negative should be clearly marked and a link to a proper replacement you should give proper instructions on how to check for proper polarity with a volt meter for those who dont know.
bob king - 返信
コメントを追加
統計データ:
過去 24時間: 4
過去 7 日: 22
過去 30 日: 116
今までの合計 105,490
