はじめに
Involves opening up the Beats Pill XL and removing the X-clamps holding the batteries in place. Disconnect the battery from the logic board and remove it from the device. You'll need to disconnect a ribbon cable to easily remove the battery.
必要な工具と部品
Gently pull on the plastic tab at the base of the ribbon cable to remove it from the motherboard.
Hola amigos y amigas como estan me pueden ayudar como puedo conseguier la placa del beatspill esta q esta aki xf urgente soy de Ecuador ciudad manta
Using your thumb and index finger, pull upwards on the base of the the power cable to remove it from the motherboard.
Using a Phillips #2 screwdriver, remove the 8 (11mm pan head Phillips #2) screws holding down the the X-clamps.
Remove the X-clamps by simply lifting upwards.
21 の人々がこのガイドを完成させました。
7 件のコメント
como saber se o problema da minha caixa e a bateria, ela nao esta carregando nem liga, a bateria porem nao esta dando 12v medicao, uma por sinal esta com carga negativa. no aguardo
Where can i buy these replacement batteries?
From here you can find a replacement battery
lisi -
It's under recall https://www.apple.com/support/beats-pill...
i think it's better to change a battery than buy a new one. And i was luck to find a replacement battery.lol
Jailene -
This was helpful, however, it is just a reference…a lot more difficult than explained here…Take your time and take photos along the way…The battery is found on Amazon…the included tools a joke…be careful…it takes time…stoked my speaker works again…https://www.amazon.com/gp/product/B073FB...
