メインコンテンツにスキップ
Beats Pill XL Battery Replacement
必要な工具と部品
  1. Beats Pill XL Battery Replacement, Case: 手順 1、 2の画像 1 Beats Pill XL Battery Replacement, Case: 手順 1、 2の画像 2
    • Using a plastic opening tool, pry the casing from the rest of the device.
    • Pry all the way around the edge and then pull apart.
    • It should be relatively easy, to pull apart. Don't be afraid to apply a necessary force.
  2. Beats Pill XL Battery Replacement: 手順 2、 1の画像 1
    • Using your thumb, remove the 8 rubber plugs in order to get to the screws.
    • Simply rub them towards the speakers and they will slide out enough to grip the edge and pull them out.
    • In the picture provided, we labeled four of them on one side of the Beats Pill XL. The other four are symmetrical to these four on the other side of the device.
  3. Beats Pill XL Battery Replacement: 手順 3、 2の画像 1 Beats Pill XL Battery Replacement: 手順 3、 2の画像 2
    • Using a Phillips #2 screwdriver, remove the 8 (10mm maxi-loc Phillips #2) screws that hold the casing together.
  4. Beats Pill XL Battery Replacement: 手順 4、 2の画像 1 Beats Pill XL Battery Replacement: 手順 4、 2の画像 2
    • Pull apart the front casing from the back casing, slowly. Try to avoid any tension on any of the connected cables.
    • Separate at a slow constant force to avoid damage to the ribbon cables.
  5. Beats Pill XL Battery Replacement: 手順 5、 2の画像 1 Beats Pill XL Battery Replacement: 手順 5、 2の画像 2
    • Gently pull on the plastic tab at the base of the ribbon cable to remove it from the motherboard.
    • Never pull the cables by the cord, as this could cause damage to the cables and/or motherboard. Always disconnect the cables from the base by the motherboard.
  6. Beats Pill XL Battery Replacement: 手順 6、 2の画像 1 Beats Pill XL Battery Replacement: 手順 6、 2の画像 2
    • Using your thumb and index finger, pull upwards on the base of the the power cable to remove it from the motherboard.
    • Even though there are two batteries, there is only one cable connecting the two to the motherboard.
  7. Beats Pill XL Battery Replacement, Battery: 手順 7、 3の画像 1 Beats Pill XL Battery Replacement, Battery: 手順 7、 3の画像 2 Beats Pill XL Battery Replacement, Battery: 手順 7、 3の画像 3
    • Using a Phillips #2 screwdriver, remove the 8 (11mm pan head Phillips #2) screws holding down the the X-clamps.
    • Remove the X-clamps by simply lifting upwards.
    • Save the 8 (11mm pan head Phillips #2) screws for reassembly as these are easy to misplace.
  8. Beats Pill XL Battery Replacement: 手順 8、 2の画像 1 Beats Pill XL Battery Replacement: 手順 8、 2の画像 2
    • Gently pull up on the plastic tab at the base of the ribbon cable to remove it from the motherboard.
  9. Beats Pill XL Battery Replacement: 手順 9、 2の画像 1 Beats Pill XL Battery Replacement: 手順 9、 2の画像 2
    • Remove the padded sticker holding down the ribbon cable to one of the batteries.
    • Use a slow constant force, as ribbon cables are fragile and could tare.
  10. Beats Pill XL Battery Replacement: 手順 10、 2の画像 1 Beats Pill XL Battery Replacement: 手順 10、 2の画像 2
    • Lift straight up from the casing to remove each batteries from their tight spaces.
終わりに
21 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Nolan
メンバー登録日: 03/11/15
855 ポイント
2のガイドは作成済み
チーム
Colorado Springs, Team 9-2, Panko Spring 2015 Colorado Springs, Team 9-2, Panko Spring 2015人のメンバー
UCCS-PANKO-S15S9G2
3 メンバー
7のガイドは作成済み
7 件のコメント
como saber se o problema da minha caixa e a bateria, ela nao esta carregando nem liga, a bateria porem nao esta dando 12v medicao, uma por sinal esta com carga negativa. no aguardo
marcosallexandre - 返信
Where can i buy these replacement batteries?
Edgar Zuniga - 返信
From here you can find a replacement battery
http://www.witpow.com/shopdvr/product/4/...
lisi -
i think it's better to change a battery than buy a new one. And i was luck to find a replacement battery.lol
Jailene -
コメントを追加
統計データ:
過去 24時間: 6
過去 7 日: 36
過去 30 日: 138
今までの合計 28,017
