メインコンテンツにスキップ
はじめに
For general disassembly guide follow this link. This guide will follow the steps taken in the general disassembly of the Beats Pill 1.0.
  1. Using the spudger, create space between the speaker covers and then remove. On the underside of the device, remove the rubber stand with the BeatsPill logo on it. Using a Philips #0 Screwdriver that is ESD-safe. Remove the 4 screws circled in blue that were underneath the rubber stand.
    • Using the spudger, create space between the speaker covers and then remove.
    • On the underside of the device, remove the rubber stand with the BeatsPill logo on it.
    • Using a Philips #0 Screwdriver that is ESD-safe. Remove the 4 screws circled in blue that were underneath the rubber stand.
  2. Remove the 2 screws circled in red with the  ESD-safe Philips #0 Screwdriver. Slowly remove the center band and 2 clip rings until the adhesive seperates as to prevent damage. Slowly remove the center band and 2 clip rings until the adhesive seperates as to prevent damage.
    • Remove the 2 screws circled in red with the ESD-safe Philips #0 Screwdriver.
    • Slowly remove the center band and 2 clip rings until the adhesive seperates as to prevent damage.
  3. Using the spudger, starting in the middle, pry the device apart along it’s seam as circled in pink. Open the device as highlighted in red to separate the two main bodies of the device. Device should look as picture above. Open the device as highlighted in red to separate the two main bodies of the device. Device should look as picture above.
    • Using the spudger, starting in the middle, pry the device apart along it’s seam as circled in pink.
    • Open the device as highlighted in red to separate the two main bodies of the device. Device should look as picture above.
  4. Circled in red is the speaker pin (yellow, red, black, white) from the mother board.    •    (Caution! Ground yourself when touching the mother board) Take a picture of the device cables connected to ensure you’re able to reconnect them correctly later. Circled in red is the speaker pin (yellow, red, black, white) from the mother board.    •    (Caution! Ground yourself when touching the mother board) Take a picture of the device cables connected to ensure you’re able to reconnect them correctly later.
    • Circled in red is the speaker pin (yellow, red, black, white) from the mother board. • (Caution! Ground yourself when touching the mother board) Take a picture of the device cables connected to ensure you’re able to reconnect them correctly later.
  5. iPhoneのバッテリーキット
    Only $29.99
    Buy Now
    iPhoneのバッテリーキット
    Only $29.99
    Buy Now
  6. Circled in red here is the NFC sensor cable. This cable has two (black and red) wires and should be removed carefully. Circled in red here is the NFC sensor cable. This cable has two (black and red) wires and should be removed carefully.
    • Circled in red here is the NFC sensor cable. This cable has two (black and red) wires and should be removed carefully.
  7. Remove control cable, highlighted in red with 5 wires (four black and one red) carefully. Remove control cable, highlighted in red with 5 wires (four black and one red) carefully.
    • Remove control cable, highlighted in red with 5 wires (four black and one red) carefully.
  8. Using a PH0 screwdriver, unscrew the four screws holding the band holding the battery in place. (screw length = 6.97 mm)
    • Using a PH0 screwdriver, unscrew the four screws holding the band holding the battery in place. (screw length = 6.97 mm)
  9. Using the same bit size remove (length = 9.11 mm) the three  screws for the motherboard and rubber stopper attached to the screw.
    • Using the same bit size remove (length = 9.11 mm) the three screws for the motherboard and rubber stopper attached to the screw.
  10. Remove the motherboard from the tabs and gently lift it out of the case. Remove the yellow NFC module with tweezers as well to completely remove the motherboard.
    • Remove the motherboard from the tabs and gently lift it out of the case. Remove the yellow NFC module with tweezers as well to completely remove the motherboard.
    Is this two batteries we need to replace? Or is just the right one the battery?
    delliskd - 返信
    The batteries I bought from Amazon came with two batteries alreaded connected to one another. One one set of leads needs to be soldered
    Scott Carpenter - 返信
  11. Remove power button and springs.
    • Remove power button and springs.
  12. Using a wirestripper strip the wires and using the wirecutters to cut the red and black wires attached to the motherboard.
    • Using a wirestripper strip the wires and using the wirecutters to cut the red and black wires attached to the motherboard.
  13. Using a soldering iron attach the new battery to the motherboard with the red wire connecting to the 0.2 volts (+) and black wire connecting to the ground (-). See the prerequisite soldering guide for more information on how to perform this step.
    • Using a soldering iron attach the new battery to the motherboard with the red wire connecting to the 0.2 volts (+) and black wire connecting to the ground (-). See the prerequisite soldering guide for more information on how to perform this step.
まとめ
20 の人々がこのガイドを完成させました。
Paul Haas
メンバー登録日: 2015年01月13日
619 ポイント
2のガイドは作成済み
チーム
USF Tampa, Team 3-2, Hickman Winter 2015 USF Tampa, Team 3-2, Hickman Winter 2015人のメンバー
USFT-HICKMAN-W15S3G2
4 メンバー
5のガイドは作成済み
donde puedo comprar la batttery para pill beats
felix - 返信
Where can you buy the replacement battery
wtmcclure - 返信
I got a replacement battery for 2.0 from Amazon, it works great! here is the link:
https://www.amazon.com/dp/B072PHZ235
And it also has battery for pill 1.0, pill XL...
Jailene -
Could you please tell what is the yellow card in the last picture?
jmestascatcoparco - 返信
Looks like the Bluetooth antenna
James Jenkins -
It is the NFC module
bobapunk -
Are there two batteries in this thing, or is the left black box a different part?
delliskd - 返信
Here a link to the replacement battery for the beats pill 1.0:
http://www.mpfproducts.com/beats-by-dr-d....
It comes with some of the tools necessary for the repair. There are two battery cells so it looks like two separate batteries but they are connected by wires and sold as one unit.
Mike - 返信
hello, my dear friend, we have remplacement battery for Beat Pill 2.0. are you interested in introducing it? feel free to contact me.
kevin zhang - 返信
コメントを追加する
統計データを表示:
過去 24時間: 45
過去 7 日: 322
過去 30 日: 1,581
今までの合計 100,282
