メインコンテンツにスキップ
Beats Mixr Headband Replacement
必要な工具と部品
  1. Beats Mixr Headband Replacement, Remove the caps on the headband: 手順 1、 1の画像 1
    • Use a spudger or prying tool to remove the cap on both sides of the headband by applying pressure where the cap meets the band. Next, you will need a Phillips head #00 screwdriver to remove the screws and washer. Twist the screwdriver into the screw and pull it apart from the washer when it becomes loose.
  2. Beats Mixr Headband Replacement, Separate the ear cuff from the headband.: 手順 2、 1の画像 1
    • Begin by pulling the two parts of the headband away from each other slowly and make sure not to break any wires. The wires will now slide free of the headband.
終わりに
29 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Allie Horton
メンバー登録日: 10/08/14
929 ポイント
1ガイドが承認済み
チーム
USF Tampa, Team 1-11, Donnelly Fall 2014 USF Tampa, Team 1-11, Donnelly Fall 2014人のメンバー
USFT-DONNELLY-F14S1G11
1 メンバー
3のガイドは作成済み
3 件のコメント
Started to disassemble my Mixr. After removing the covers I found the screws not so easy to remove as stated. For one, they must have used lock tite. In addition the nut and screw are so tight a screw driver will not work. Mine has spanner type nuts. I need to find a wrench that will fit.
Has anyone ran into this.
Robert Schumann - 返信
Did you figure out how to get the screws out without breaking?
simmons4jesus -
The replacement parts listed are for studio not mixr and the colors dont match!
Missy Truth - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 7
過去 30 日: 33
今までの合計 14,411
