はじめに
The air/ oxygen blender combines the pure oxygen gas with filtered, compressed air to create the proper mixture at the right pressure for the patient. An incorrect mixing or an incorrect pressure will indicate a problem with the unit and will signal a need of change. Found on page 85 in the full service manual.
必要な工具と部品
Remove the ribbon cable at the connection on the oxygen blender control board.
To reassemble your device, follow these instructions in reverse order. Perform an OVP test to check proper installment.
NOTE: do not interchange control boards with non-socketed ones!
ある他の人がこのガイドを完成しました。
