メインコンテンツにスキップ
Canon PowerShot A630 Battery Door Replacement
必要な工具と部品
  1. Canon PowerShot A630 Battery Door Replacement, Front Panel: 手順 1、 2の画像 1 Canon PowerShot A630 Battery Door Replacement, Front Panel: 手順 1、 2の画像 2
    • Open the battery door by sliding the tab on the battery door while pushing the battery door away from the camera.
    • Remove batteries.
  2. Canon PowerShot A630 Battery Door Replacement: 手順 2、 2の画像 1 Canon PowerShot A630 Battery Door Replacement: 手順 2、 2の画像 2
    • Remove the three indicated .2mm screws using a Phillips #00 screwdriver.
    • Gently pull off side-panel to remove it.
  3. Canon PowerShot A630 Battery Door Replacement: 手順 3、 1の画像 1
    • Remove the two indicated .2mm screws using a Phillips #00 screwdriver.
  4. Canon PowerShot A630 Battery Door Replacement: 手順 4、 2の画像 1 Canon PowerShot A630 Battery Door Replacement: 手順 4、 2の画像 2
    • Remove the indicated .2mm screw using a Phillips #00 screwdriver.
    • Remove the three .2mm screws located on the internal side of the top panel within the battery chamber using a Phillips #00 screwdriver.
  5. Canon PowerShot A630 Battery Door Replacement: 手順 5、 2の画像 1 Canon PowerShot A630 Battery Door Replacement: 手順 5、 2の画像 2
    • Open 'DIGITAL A/V OUT' door on camera.
  6. Canon PowerShot A630 Battery Door Replacement: 手順 6、 1の画像 1
    • Grip the sides of the top panel and gently pull to separate the top panel from the camera body.
    • The top panel will not completely detach.
  7. Canon PowerShot A630 Battery Door Replacement: 手順 7、 2の画像 1 Canon PowerShot A630 Battery Door Replacement: 手順 7、 2の画像 2
    • Gently pull the front and back panels apart, and use a Phillips #00 screwdriver to remove the screw connecting the panels.
    • Gripping the top and bottom, gently pull the front panel away from the camera body to remove it.
  8. Canon PowerShot A630 Battery Door Replacement, Back Panel: 手順 8、 2の画像 1 Canon PowerShot A630 Battery Door Replacement, Back Panel: 手順 8、 2の画像 2
    • Use the spudger to gently pull back the retaining clip and pull the ribbon out.
    • The top panel should now be completely detached from the camera.
    • Applying too much force to the spudger may damage the retaining clip.
  9. Canon PowerShot A630 Battery Door Replacement: 手順 9、 2の画像 1 Canon PowerShot A630 Battery Door Replacement: 手順 9、 2の画像 2
    • Remove .2 mm screw using a #00 Philips screwdriver.
    • Gently pry off back panel to remove it.
  10. Canon PowerShot A630 Battery Door Replacement, Battery Door: 手順 10、 1の画像 1
    • Remover .2 mm screw using a #00 Philips screwdriver.
  11. Canon PowerShot A630 Battery Door Replacement: 手順 11、 2の画像 1 Canon PowerShot A630 Battery Door Replacement: 手順 11、 2の画像 2
    • Using tweezers, gently pull remove the small rod in the battery door hinge.
  12. Canon PowerShot A630 Battery Door Replacement: 手順 12、 2の画像 1 Canon PowerShot A630 Battery Door Replacement: 手順 12、 2の画像 2
    • Gently pull up on the battery door to remove it.
終わりに
2 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Alicia Burns
メンバー登録日: 10/13/14
574 ポイント
5のガイドは作成済み
チーム
Clemson, Team 2-5, Benson Fall 2014 Clemson, Team 2-5, Benson Fall 2014人のメンバー
CLEM-BENSON-F14S2G5
4 メンバー
18のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 6
過去 30 日: 39
今までの合計 1,305
