メインコンテンツにスキップ
Batteries in Nikon Coolpix 4600 Replacement
必要な工具と部品
  1. Batteries in Nikon Coolpix 4600 Replacement, Batteries: 手順 1、 1の画像 1
    • Locate the battery compartment on the bottom right of the camera.
  2. Batteries in Nikon Coolpix 4600 Replacement: 手順 2、 2の画像 1 Batteries in Nikon Coolpix 4600 Replacement: 手順 2、 2の画像 2
    • While holding the camera with the lens facing toward you, slide the lock button to the right and pull the battery door towards you. The battery door should pop open.
    • If the door does not pop open, gently lift the door using your finger.
  3. Batteries in Nikon Coolpix 4600 Replacement: 手順 3、 1の画像 1
    • Remove the dead batteries. The easiest way to do this is by turning the camera right side up and gently tapping the lens side of the camera against your hand until they fall out. If this does not work, you can simply pull them out.
  4. Batteries in Nikon Coolpix 4600 Replacement: 手順 4、 1の画像 1
    • Insert fresh AA batteries into the compartment as demonstrated in the picture to the left. The orientation of the batteries is important to ensure the camera works properly.
    • Close the battery door.
    • Remember to slide the switch back into the lock position.
終わりに
Reassembly of the camera is the final step in the guide.
作成者
6人の作成者と共同で作成されました。
Richard
メンバー登録日: 04/19/12
9 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team 9-43, Regan Spring 2012 Cal Poly, Team 9-43, Regan Spring 2012人のメンバー
CPSU-REGAN-S12S9G43
5 メンバー
12のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 23
過去 30 日: 71
今までの合計 2,877
