メインコンテンツにスキップ
Bathroom Sink Knob Replacement with the "Danco Faucet Remodeling Kit for Delta"
必要な工具と部品
  1. Bathroom Sink Knob Replacement with the "Danco Faucet Remodeling Kit for Delta", Knobs: 手順 1、 2の画像 1 Bathroom Sink Knob Replacement with the "Danco Faucet Remodeling Kit for Delta", Knobs: 手順 1、 2の画像 2
    • Underneath the sink there are two valves that supply water to each knob. Turn off the supply by twisting the valves tightly to the right.
    • The water supply needs to be off before starting the replacement. Failure to do so can result in water spouting all over the area, causing damage.
  2. Bathroom Sink Knob Replacement with the "Danco Faucet Remodeling Kit for Delta": 手順 2、 2の画像 1 Bathroom Sink Knob Replacement with the "Danco Faucet Remodeling Kit for Delta": 手順 2、 2の画像 2
    • Double-check that the water supply is off by twisting the faucet knobs to the left.
  3. Bathroom Sink Knob Replacement with the "Danco Faucet Remodeling Kit for Delta": 手順 3、 2の画像 1 Bathroom Sink Knob Replacement with the "Danco Faucet Remodeling Kit for Delta": 手順 3、 2の画像 2
    • With the 1/8” flathead screwdriver, insert through the groove on the edge of the hot-n-cold caps, loosen, and remove them.
  4. Bathroom Sink Knob Replacement with the "Danco Faucet Remodeling Kit for Delta": 手順 4、 2の画像 1 Bathroom Sink Knob Replacement with the "Danco Faucet Remodeling Kit for Delta": 手順 4、 2の画像 2
    • Using the PZ1 starhead screwdriver, loosen the 19.1 mm oval head screw.
  5. Bathroom Sink Knob Replacement with the "Danco Faucet Remodeling Kit for Delta": 手順 5、 3の画像 1 Bathroom Sink Knob Replacement with the "Danco Faucet Remodeling Kit for Delta": 手順 5、 3の画像 2 Bathroom Sink Knob Replacement with the "Danco Faucet Remodeling Kit for Delta": 手順 5、 3の画像 3
    • Remove the 19.1 mm oval head screw by pulling it up from the knob.
    • Lift the knob from the faucet to remove it.
  6. Bathroom Sink Knob Replacement with the "Danco Faucet Remodeling Kit for Delta": 手順 6、 2の画像 1 Bathroom Sink Knob Replacement with the "Danco Faucet Remodeling Kit for Delta": 手順 6、 2の画像 2
    • Use an adjustable wrench to loosen the bonnet nut.
  7. Bathroom Sink Knob Replacement with the "Danco Faucet Remodeling Kit for Delta": 手順 7、 2の画像 1 Bathroom Sink Knob Replacement with the "Danco Faucet Remodeling Kit for Delta": 手順 7、 2の画像 2
    • Remove the bonnet nut from the faucet.
  8. Bathroom Sink Knob Replacement with the "Danco Faucet Remodeling Kit for Delta": 手順 8、 2の画像 1 Bathroom Sink Knob Replacement with the "Danco Faucet Remodeling Kit for Delta": 手順 8、 2の画像 2
    • Remove the escutcheon by pulling it out from the valve.
  9. Bathroom Sink Knob Replacement with the "Danco Faucet Remodeling Kit for Delta": 手順 9、 2の画像 1 Bathroom Sink Knob Replacement with the "Danco Faucet Remodeling Kit for Delta": 手順 9、 2の画像 2
    • Place the new escutcheon by pushing it down into the valve.
  10. Bathroom Sink Knob Replacement with the "Danco Faucet Remodeling Kit for Delta": 手順 10、 2の画像 1 Bathroom Sink Knob Replacement with the "Danco Faucet Remodeling Kit for Delta": 手順 10、 2の画像 2
    • Install the new bonnet nut by placing it over and around the escutcheon.
  11. Bathroom Sink Knob Replacement with the "Danco Faucet Remodeling Kit for Delta": 手順 11、 2の画像 1 Bathroom Sink Knob Replacement with the "Danco Faucet Remodeling Kit for Delta": 手順 11、 2の画像 2
    • Using an adjustable wrench, tighten the bonnet nut by twisting it to the right.
  12. Bathroom Sink Knob Replacement with the "Danco Faucet Remodeling Kit for Delta": 手順 12、 2の画像 1 Bathroom Sink Knob Replacement with the "Danco Faucet Remodeling Kit for Delta": 手順 12、 2の画像 2
    • Install the new knob by placing it on top and around the escutcheon and bonnet nut.
  13. Bathroom Sink Knob Replacement with the "Danco Faucet Remodeling Kit for Delta": 手順 13、 2の画像 1 Bathroom Sink Knob Replacement with the "Danco Faucet Remodeling Kit for Delta": 手順 13、 2の画像 2
    • Insert the 19.1 mm oval head screw into the top of the knob.
  14. Bathroom Sink Knob Replacement with the "Danco Faucet Remodeling Kit for Delta": 手順 14、 2の画像 1 Bathroom Sink Knob Replacement with the "Danco Faucet Remodeling Kit for Delta": 手順 14、 2の画像 2
    • Using the PZ1 starhead screwdriver, tighten the screw by twisting it to the right.
  15. Bathroom Sink Knob Replacement with the "Danco Faucet Remodeling Kit for Delta": 手順 15、 2の画像 1 Bathroom Sink Knob Replacement with the "Danco Faucet Remodeling Kit for Delta": 手順 15、 2の画像 2
    • Install the new hot-n-cold caps by snapping them onto the top of the knobs.
  16. Bathroom Sink Knob Replacement with the "Danco Faucet Remodeling Kit for Delta": 手順 16、 2の画像 1 Bathroom Sink Knob Replacement with the "Danco Faucet Remodeling Kit for Delta": 手順 16、 2の画像 2
    • Turn on the water supply by twisting the valves to the left.
終わりに
Test that the replacement was done correctly and that the water supply is on by twisting the faucet knobs to the right. Enjoy your new remodeled faucet!
ある他の人がこのガイドを完成しました。
作成者
1人の作成者と共同作成されました。
Benjamin Figueroa
メンバー登録日: 09/23/23
295 ポイント
1ガイドが承認済み
チーム
Austin Community College, Team 1-5, Watkins Fall 2023 Austin Community College, Team 1-5, Watkins Fall 2023人のメンバー
AUSTINCC-WATKINS-F23S1G5
1 メンバー
1のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 9
過去 30 日: 40
今までの合計 447
