はじめに
There are two kinds of replacement slides: ball bearing and roller slides. The ball-bearing slides are the most frequent, whereas the roller slides are utilized for heavier drawers. I shall utilize ball-bearing drops in this tutorial since they are quiet and smooth. Although drawer slides are meant to be sturdy and last a lifetime, it may be essential to replace them on sometimes. With this article, I will demonstrate the simplest method to repair your drawer slides if they get worn or if the weight of the drawer prevents it from functioning effectively.
必要な工具と部品
Before starting, remove the existing sliders and brackets by unscrewing the screws in a counterclockwise direction.
Enjoy your new drawer!
ある他の人がこのガイドを完成しました。
