メインコンテンツにスキップ
Barreto Trencher E718MTH4S 2016 Chain Replacement
必要な工具と部品
  1. Barreto Trencher E718MTH4S 2016 Chain Replacement, Engage the hub lock pins: 手順 1、 3の画像 1 Barreto Trencher E718MTH4S 2016 Chain Replacement, Engage the hub lock pins: 手順 1、 3の画像 2 Barreto Trencher E718MTH4S 2016 Chain Replacement, Engage the hub lock pins: 手順 1、 3の画像 3
    • Make sure that both ignition switches are turned to the off position. There is one on the engine and one on the control panel.
    • Pull the ring near one of the wheel hubs straight out, away from the wheel.
    • Rotate it so that the small roll pin lines up with its slot.
    • Release the ring so that the lock pin slides into the wheel. You may need to rotate the wheels a little before the lock pin fully engages.
    • With the pin engaged, it should be very hard to turn the wheels.
    • Repeat this step so that the lock pins on both wheels are engaged.
  2. Barreto Trencher E718MTH4S 2016 Chain Replacement, Rotate the auger: 手順 2、 2の画像 1 Barreto Trencher E718MTH4S 2016 Chain Replacement, Rotate the auger: 手順 2、 2の画像 2
    • Rotate the auger to move the chain until its master link (the link with the removable pin) is easily accessible.
  3. Barreto Trencher E718MTH4S 2016 Chain Replacement, Remove the cotter pin: 手順 3、 3の画像 1 Barreto Trencher E718MTH4S 2016 Chain Replacement, Remove the cotter pin: 手順 3、 3の画像 2 Barreto Trencher E718MTH4S 2016 Chain Replacement, Remove the cotter pin: 手順 3、 3の画像 3
    • Use a pair of needle-nose pliers to straighten both sides of the cotter pin securing the pin in the master link.
  4. Barreto Trencher E718MTH4S 2016 Chain Replacement: 手順 4、 2の画像 1 Barreto Trencher E718MTH4S 2016 Chain Replacement: 手順 4、 2の画像 2
    • Pull the cotter pin out of the chain pin.
  5. Barreto Trencher E718MTH4S 2016 Chain Replacement, Reassembly note: 手順 5、 3の画像 1 Barreto Trencher E718MTH4S 2016 Chain Replacement, Reassembly note: 手順 5、 3の画像 2 Barreto Trencher E718MTH4S 2016 Chain Replacement, Reassembly note: 手順 5、 3の画像 3
    • When you reinstall the chain, use a new cotter pin.
    • Insert the new cotter pin into the chain pin.
    • Use a set of needle-nose pliers to bend each half of the cotter pin back around the chain pin to secure the cotter pin.
  6. Barreto Trencher E718MTH4S 2016 Chain Replacement, Remove the master link pin: 手順 6、 3の画像 1 Barreto Trencher E718MTH4S 2016 Chain Replacement, Remove the master link pin: 手順 6、 3の画像 2 Barreto Trencher E718MTH4S 2016 Chain Replacement, Remove the master link pin: 手順 6、 3の画像 3
    • Turn the auger to move the chain until the master link is positioned on top of the boom.
    • In this position, the link is easier to access and the chain is braced against the guide on the boom.
    • Place the smaller, flat end of a 3/16 inch pin punch against the end of the master link pin that previously held the cotter pin.
    • Hit the larger end of the punch with a heavy hammer to tap the pin out of the master link.
    • Be very careful to avoid hitting your hand. Don't hold the punch too close to either end, and realign the hammer and punch after each swing.
    • If the pin is stuck, it may help to apply some kind of penetrating lubricant to the interface between the chain and the pin. Allow the lubricant to sit for a few minutes before trying again.
    • If you are still having trouble, a two-jaw gear puller or in-line pin puller might work better. When using a gear puller, it might be necessary to stabilize the claw side of the puller with some kind of spacer that won't be crushed when you start pushing the pin out. A 3/4 inch socket works well.
    • When using a gear puller, the master link has to be underneath the boom to allow adequate space for the puller arms. Turn the auger to move the chain so the master link is positioned properly.
  7. Barreto Trencher E718MTH4S 2016 Chain Replacement: 手順 7、 3の画像 1 Barreto Trencher E718MTH4S 2016 Chain Replacement: 手順 7、 3の画像 2 Barreto Trencher E718MTH4S 2016 Chain Replacement: 手順 7、 3の画像 3
    • The chain is very heavy and will drop off the boom as soon as the pin is removed from the master link. Make sure your hands are out of the way and nothing fragile is underneath the chain before you remove the pin.
    • Pull the pin out of the master link.
    • When you reassemble the chain, you will need significant force to push the pin all the way back into the master link. Use a heavy hammer and a pin punch to push the pin back into place.
  8. Barreto Trencher E718MTH4S 2016 Chain Replacement, Remove the chain: 手順 8、 2の画像 1 Barreto Trencher E718MTH4S 2016 Chain Replacement, Remove the chain: 手順 8、 2の画像 2
    • Lift the chain off of the dig sprocket and chain roller and remove it from the trencher.
終わりに
When you reassemble the chain, make sure to use a new cotter pin.
After reassembly, make sure the chain is properly tensioned and grease the chain roller Zerk fitting.
2 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
Adam O'Camb
メンバー登録日: 04/11/15
196,299 ポイント
416のガイドは作成済み
コメント 1 件
Parts section has wrong chain listed. Chain listed is a roller chain which I am assuming is for the wheel drive. Trenching chain part # as of 10/27/23 is 03626-4S. 18" welded shark.
ROBI BRYANT - 返信
コメントを追加
統計データ:
過去 24時間: 5
過去 7 日: 21
過去 30 日: 47
今までの合計 2,877
