メインコンテンツにスキップ
Barreto Tillers E1320HTRLR 2016 Tine Replacement
必要な工具と部品
  1. Barreto Tillers E1320HTRLR 2016 Tine Replacement, Disconnect the spark plug wire: 手順 1、 2の画像 1 Barreto Tillers E1320HTRLR 2016 Tine Replacement, Disconnect the spark plug wire: 手順 1、 2の画像 2
    • Before you begin, ensure that the engine is powered down and cool to the touch.
    • Grab the plastic housing at the end of the spark plug wire and pull firmly to disconnect it.
  2. Barreto Tillers E1320HTRLR 2016 Tine Replacement, Flip the engine switch to the off position: 手順 2、 2の画像 1 Barreto Tillers E1320HTRLR 2016 Tine Replacement, Flip the engine switch to the off position: 手順 2、 2の画像 2
    • Flip the red engine ON/OFF switch to the OFF position.
  3. Barreto Tillers E1320HTRLR 2016 Tine Replacement, Close the fuel valve: 手順 3、 2の画像 1 Barreto Tillers E1320HTRLR 2016 Tine Replacement, Close the fuel valve: 手順 3、 2の画像 2
    • Flip the fuel valve lever to the OFF position.
  4. Barreto Tillers E1320HTRLR 2016 Tine Replacement, Turn off the ignition: 手順 4、 2の画像 1 Barreto Tillers E1320HTRLR 2016 Tine Replacement, Turn off the ignition: 手順 4、 2の画像 2
    • Flip the ignition switch to the OFF position.
    • Ensure the wheel drive control lever is set to the neutral position.
  5. Barreto Tillers E1320HTRLR 2016 Tine Replacement, Allow the wheels to freewheel: 手順 5、 3の画像 1 Barreto Tillers E1320HTRLR 2016 Tine Replacement, Allow the wheels to freewheel: 手順 5、 3の画像 2 Barreto Tillers E1320HTRLR 2016 Tine Replacement, Allow the wheels to freewheel: 手順 5、 3の画像 3
    • Pull the locking pin out and rotate it 90˚ to unlock the right wheel from the hub.
    • Repeat for the left wheel.
  6. Barreto Tillers E1320HTRLR 2016 Tine Replacement, Add wheel chocks: 手順 6、 1の画像 1
    • Insert wheel chocks underneath each wheel to keep the device stationary during disassembly.
  7. Barreto Tillers E1320HTRLR 2016 Tine Replacement, Loosen the tine bolts: 手順 7、 3の画像 1 Barreto Tillers E1320HTRLR 2016 Tine Replacement, Loosen the tine bolts: 手順 7、 3の画像 2 Barreto Tillers E1320HTRLR 2016 Tine Replacement, Loosen the tine bolts: 手順 7、 3の画像 3
    • Use a 5/8 inch socket with an 11/16 inch wrench to loosen the two 5/8 inch bolts and two 11/16 inch nuts securing the tine to the tine shaft.
    • Remove the two tine nuts.
  8. Barreto Tillers E1320HTRLR 2016 Tine Replacement, Remove the tine bolts: 手順 8、 2の画像 1 Barreto Tillers E1320HTRLR 2016 Tine Replacement, Remove the tine bolts: 手順 8、 2の画像 2
    • Remove the two bolts holding the tine to the tine shaft.
    • During reassembly, use Loctite 271 on tine bolt threads to prevent them from loosening.
  9. Barreto Tillers E1320HTRLR 2016 Tine Replacement, Remove the tine: 手順 9、 2の画像 1 Barreto Tillers E1320HTRLR 2016 Tine Replacement, Remove the tine: 手順 9、 2の画像 2
    • Remove the tine.
    • Repeat this procedure for each tine you need to replace.
    • Keep track of each tine's orientation.
終わりに
Carsten Frauenheim
メンバー登録日: 03/10/20
146,268 ポイント
424のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Staff
119 メンバー
21,981のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 4
過去 30 日: 12
今までの合計 656
