メインコンテンツにスキップ
Barrel Reloading Mechanishm
必要な工具と部品
  1. Barrel Reloading Mechanishm, Barrel Reloading Mechanism: 手順 1、 2の画像 1 Barrel Reloading Mechanishm, Barrel Reloading Mechanism: 手順 1、 2の画像 2
    • Unscrew all of the 12 screws on the Nerf gun.
  2. Barrel Reloading Mechanishm: 手順 2、 1の画像 1
    • Remember to remove the grey part of the reloader that is not attached to the gun.
  3. Barrel Reloading Mechanishm: 手順 3、 2の画像 1 Barrel Reloading Mechanishm: 手順 3、 2の画像 2
    • Remove top outer shell.
    • Remove orange attachment tab.
  4. Barrel Reloading Mechanishm: 手順 4、 2の画像 1 Barrel Reloading Mechanishm: 手順 4、 2の画像 2
    • Remove the screw that holds the trigger in place.
  5. Barrel Reloading Mechanishm: 手順 5、 2の画像 1 Barrel Reloading Mechanishm: 手順 5、 2の画像 2
    • Remove the reloader trigger that is triggered by the trigger. Lol I just had to say that.
    • Putting this piece back in the gun can be frustrating since it is spring loaded. Here's a tip. Put the orange trigger(the piece in the red circle) on first, than slip the spring through the opening on the piece.
  6. Barrel Reloading Mechanishm: 手順 6、 2の画像 1 Barrel Reloading Mechanishm: 手順 6、 2の画像 2
    • Remove the barrel that holds the Nerf darts.
    • Be careful on removing the barrel since it could do more harm to your already damaged barrel reloader.
  7. Barrel Reloading Mechanishm: 手順 7、 2の画像 1 Barrel Reloading Mechanishm: 手順 7、 2の画像 2
    • Remove the air piston and barrel turning part. This is the part you will be working on.
  8. Barrel Reloading Mechanishm: 手順 8、 1の画像 1
    • Move the other parts of the Nerf gun away from the air piston and barrel rotator part.
  9. Barrel Reloading Mechanishm: 手順 9、 2の画像 1 Barrel Reloading Mechanishm: 手順 9、 2の画像 2
    • Remove screws from the piece that is holding the barrel reloading piston in place.
  10. Barrel Reloading Mechanishm: 手順 10、 1の画像 1
    • Remove the piece holding the barrel reloading piston.
  11. Barrel Reloading Mechanishm: 手順 11、 1の画像 1
    • If your piston looks like this in the picture, you will need to either find a screw that is less than or equal to the size of one of the screws on your weapon.
  12. Barrel Reloading Mechanishm: 手順 12、 3の画像 1 Barrel Reloading Mechanishm: 手順 12、 3の画像 2 Barrel Reloading Mechanishm: 手順 12、 3の画像 3
    • Once you have found a screw, use a hot glue gun or super glue and layer it around the screw to keep it from wobbling.
  13. Barrel Reloading Mechanishm: 手順 13、 1の画像 1
    • It is a good idea to test the barrel reloading mechanism by pulling the barrel reloading piston back and forth. If the orange circle that attaches to the dart barrel spins then that is a good sign.
    • If it is not working, try pulling the screw out and screw (or push) it back in the other way.
  14. Barrel Reloading Mechanishm: 手順 14、 1の画像 1
    • This is what your array of parts should look like.
    • Make sure you do NOT loose the spring circled in red in the picture. If you do then your weapon will have to be a manual reloading gun.
  15. Barrel Reloading Mechanishm: 手順 15、 1の画像 1
    • The rough white cylinder circled in red on this picture will be covered in some grease. Do NOT wash it off.
  16. Barrel Reloading Mechanishm: 手順 16、 2の画像 1 Barrel Reloading Mechanishm: 手順 16、 2の画像 2
    • Now put the piston back in place.
  17. Barrel Reloading Mechanishm: 手順 17、 3の画像 1 Barrel Reloading Mechanishm: 手順 17、 3の画像 2 Barrel Reloading Mechanishm: 手順 17、 3の画像 3
    この手順で使用する道具:
    • Now grab your tweezers and place the spring back in place by attaching it on the two white poles circled in red. This is something you should do if your spring fell off.
  18. Barrel Reloading Mechanishm, Tips:: 手順 18、 3の画像 1 Barrel Reloading Mechanishm, Tips:: 手順 18、 3の画像 2 Barrel Reloading Mechanishm, Tips:: 手順 18、 3の画像 3
    • Tips:
    • If any of the springs fall off inside the weapon or the weapon's parts you can use the tweezers to grab them.
    • If your Nerf Elite Strongarm is still not working here is a link to a Reddit post posted by someone who had a similiar problem.Strongarm barrel doesn't rotate
    • Sometimes during use the barrel will need to be turned(but make sure you do not push it beyond its limits) or you can just jerk the gun to the side.
終わりに
4 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
[deleted]
メンバー登録日: 03/09/17
405 ポイント
2のガイドは作成済み
4件のガイドコメント
Excellent guide, thanks for putting it together! We got a brand new Strongarm we couldn’t return so I followed your guide to take it apart. However, nothing was broken.
We noticed the barrel rotated fine when manually pulling the mechanism when the blaster was apart, but it wasn’t rotating when screwed back together. I applied some Super Lube grease to several areas in the mechanism where I thought friction might be introduced and, voila! The blaster fires and slam fires reliably.
Without your guide I would’ve been really stuck, though. Thank you!
Jeremiah - 返信
You’re welcome!
[deleted] -
Thank you! I realized after this that one of my springs was out of place, and so the blaster was not working properly. Thank you for the help!
Cameron Minnes - 返信
No problem! Happy to help! :)
[deleted] -
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 5
過去 30 日: 38
今までの合計 9,170
