メインコンテンツにスキップ
Barnes And Noble Nook HD Tablet Screen Replacement
必要な工具と部品
  1. Barnes And Noble Nook HD Tablet Screen Replacement, Remove the front screen: 手順 1、 3の画像 1 Barnes And Noble Nook HD Tablet Screen Replacement, Remove the front screen: 手順 1、 3の画像 2 Barnes And Noble Nook HD Tablet Screen Replacement, Remove the front screen: 手順 1、 3の画像 3
    • wedge the plastic opening piece underneath the bottom left hand corner of the front frame. Pry the frame off of the Nook.
  2. Barnes And Noble Nook HD Tablet Screen Replacement, Remove the screws: 手順 2、 2の画像 1 Barnes And Noble Nook HD Tablet Screen Replacement, Remove the screws: 手順 2、 2の画像 2
    • Remove every visible screw tying the chassis to the bottom frame using the T-4 attachment for the screwdriver in the iFixit screwdriver kit.
  3. Barnes And Noble Nook HD Tablet Screen Replacement, Remove the chassis: 手順 3、 1の画像 1
  4. Barnes And Noble Nook HD Tablet Screen Replacement, Detach battery: 手順 4、 1の画像 1
    • detach the battery ribbon from the motherboard.
  5. Barnes And Noble Nook HD Tablet Screen Replacement, Flip the nook: 手順 5、 1の画像 1
    • flip center chassis so that the back of the screen is facing you, and the hole is positioned in the bottom right corner.
  6. Barnes And Noble Nook HD Tablet Screen Replacement, Detach the screen from chassis part 1: 手順 6、 3の画像 1 Barnes And Noble Nook HD Tablet Screen Replacement, Detach the screen from chassis part 1: 手順 6、 3の画像 2 Barnes And Noble Nook HD Tablet Screen Replacement, Detach the screen from chassis part 1: 手順 6、 3の画像 3
    • Remove copper tape above the antenna, 3 quarters of the way up the left side of the nook.
  7. Barnes And Noble Nook HD Tablet Screen Replacement, Detach the screen from chassis part 2: 手順 7、 2の画像 1 Barnes And Noble Nook HD Tablet Screen Replacement, Detach the screen from chassis part 2: 手順 7、 2の画像 2
    この手順で使用する道具:
    • Locate thin orange strip on the top side of the motherboard. Apply tweezers to the black casing that locks it into the motherboard (plastic piece will completely come out).
  8. Barnes And Noble Nook HD Tablet Screen Replacement, Detach the screen from chassis part 3: 手順 8、 2の画像 1 Barnes And Noble Nook HD Tablet Screen Replacement, Detach the screen from chassis part 3: 手順 8、 2の画像 2
    • Locate the foam covered orange strip on the motherboard. Pull up (away from motherboard) so that it i no longer connected to the motherboard.
  9. Barnes And Noble Nook HD Tablet Screen Replacement, Take motherboard away from the screen: 手順 9、 2の画像 1 Barnes And Noble Nook HD Tablet Screen Replacement, Take motherboard away from the screen: 手順 9、 2の画像 2
    • Lift motherboard away from the screen. Pull frame off of the screen.
  10. Barnes And Noble Nook HD Tablet Screen Replacement, Place new screen: 手順 10、 2の画像 1 Barnes And Noble Nook HD Tablet Screen Replacement, Place new screen: 手順 10、 2の画像 2
    • Put the new screen back into place in the frame (the reverse of step 9). Place motherboard back into place on the back of the screen. And follow steps in reverse order to reassemble.
終わりに
9 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Elijah Gonsalves
メンバー登録日: 10/24/14
1,049 ポイント
3のガイドは作成済み
チーム
UMass Dartmouth, Team 2-3, Duarte Fall 2014 UMass Dartmouth, Team 2-3, Duarte Fall 2014人のメンバー
UMASSD-DUARTE-F14S2G3
5 メンバー
10のガイドは作成済み
1件のガイドコメント
como faço para comprar a tela touch do tablet nook ce0984
sou de Fortaleza-Ceara - Brasil
meu e-mail é moreiragenesio@yahoo.com.br
moreiragenesio - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 12
過去 30 日: 25
今までの合計 14,645
