メインコンテンツにスキップ
Barbie Doll Hair Replacement
必要な工具と部品
  1. Barbie Doll Hair Replacement, Barbie Doll Hair: 手順 1、 3の画像 1 Barbie Doll Hair Replacement, Barbie Doll Hair: 手順 1、 3の画像 2 Barbie Doll Hair Replacement, Barbie Doll Hair: 手順 1、 3の画像 3
    • Use light force to pull barbie head off of the body.
    • If stuck, soak in warm water to loosen.
  2. Barbie Doll Hair Replacement: 手順 2、 2の画像 1 Barbie Doll Hair Replacement: 手順 2、 2の画像 2
    この手順で使用する道具:
    購入する
    • Cut off all of the remaining hair using scissors.
    • Tweezers may be used once hair is too short for scissors.
    • It is important to remove as much hair as possible.
  3. Barbie Doll Hair Replacement: 手順 3、 3の画像 1 Barbie Doll Hair Replacement: 手順 3、 3の画像 2 Barbie Doll Hair Replacement: 手順 3、 3の画像 3
    • Cut the yarn pieces for doll hair.
    • With a ruler, measure equal pieces twice as long as intended hair length.
    • Cut enough for desired hair thickness.
    • To make up for inconsistencies in length, you may cut pieces longer and trim later.
  4. Barbie Doll Hair Replacement: 手順 4、 3の画像 1 Barbie Doll Hair Replacement: 手順 4、 3の画像 2 Barbie Doll Hair Replacement: 手順 4、 3の画像 3
    • Thread yarn between the forked tip of the reroot tool.
    • Attempt to thread the yarn at its midpoint for more even hair.
    • Insert the reroot tool into a small hole atop the doll's head.
    • Push the yarn inside as far as the tool will allow.
    • Remove the reroot tool from the head, leaving the yarn tucked inside.
  5. Barbie Doll Hair Replacement: 手順 5、 1の画像 1
    • Add glue to the inside of the doll's head.
    • Plug in and preheat the glue gun.
    • Insert glue gun from the base of the head.
    • Add a thicker layer of glue for stronger hair.
    • Hot glue can cause burns when exposed directly to skin.
  6. Barbie Doll Hair Replacement: 手順 6、 1の画像 1
    • After applying glue, use the blunt end of the rerooting tool to spread glue to cover the inside of the head.
    • Do this immediately after applying glue, because it will dry quickly.
  7. Barbie Doll Hair Replacement: 手順 7、 2の画像 1 Barbie Doll Hair Replacement: 手順 7、 2の画像 2
    • Wait for the glue to dry (15-30 minutes).
    • Once the glue is dry, attach the Barbie head back onto the neck joint.
    • For extra styling and volume, you may separate yarn strands.
ゴール
ある他の人がこのガイドを完成しました。
作成者
4人の作成者と共同で作成されました。
Miranda Comstock
メンバー登録日: 01/31/23
170 ポイント
1ガイドが承認済み
チーム
UC Davis, Team 2-3, Andersen Winter 2023 UC Davis, Team 2-3, Andersen Winter 2023人のメンバー
UCD-ANDERSEN-W23S2G3
3 メンバー
2のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 15
過去 30 日: 69
今までの合計 1,743
