メインコンテンツにスキップ
Back Case
必要な工具と部品
  1. Back Case, Battery: 手順 1、 1の画像 1
    • Orient camera to look directly at battery compartment side as shown.
  2. Back Case: 手順 2、 3の画像 1 Back Case: 手順 2、 3の画像 2 Back Case: 手順 2、 3の画像 3
    • Locate the two latches on the battery compartment.
    • First, move the "lock" switch left to reveal red indicator.
    • Next, move the "cover latch" switch downward to reveal red indicator.
    • You have to move the switches in that order for the compartment to unlatch.
  3. Back Case: 手順 3、 2の画像 1 Back Case: 手順 3、 2の画像 2
    • Allow the battery compartment latch to completely open.
    • Insert battery with the writing face up.
    • The bigger slot is for the battery. The smaller slot is for the memory card.
    • Battery not shown.
  4. Back Case, Back Case: 手順 4、 1の画像 1
    • Orient the camera so you are looking at the bottom.
    • Remove the three 3.85mm Phillips #00 screws from the bottom of the camera.
  5. Back Case: 手順 5、 1の画像 1
    • Orient the camera so you are looking at the side plate.
    • Remove the two 3.15mm Phillips #00 screws from the side plate of the camera.
  6. Back Case: 手順 6、 2の画像 1 Back Case: 手順 6、 2の画像 2
    • Orient the camera so you are looking at the front plate.
    • Remove the two 3.8mm with the Phillips H1.5 from the front plate.
    • Remove the "Olympus" plate.
  7. Back Case: 手順 7、 1の画像 1
    • Remove face plate.
  8. Back Case: 手順 8、 3の画像 1 Back Case: 手順 8、 3の画像 2 Back Case: 手順 8、 3の画像 3
    • Locate three small black screws inside of the battery compartment.
    • Remove the 3.85mm Phillips #00 screw on the far left side.
    • Remove the two 5mm Phillips #00 screws on the right side
  9. Back Case: 手順 9、 3の画像 1 Back Case: 手順 9、 3の画像 2 Back Case: 手順 9、 3の画像 3
    • Orient the camera to be look at the top.
    • Remove the 5.4mm Phillips #00 screw on the top left side.
    • Remove the 7.4mm Phillips #00 screw next to the "ON/OFF" label.
    • Pry off top button plate with black nylon spudger.
  10. Back Case: 手順 10、 2の画像 1 Back Case: 手順 10、 2の画像 2
    • Rotate to bottom of camera and locate bottom latch.
    • Wedge black nylon spudger in between bottom latch and camera base to release LCD Screen from camera.
    • Push firmly apart.
    • Some buttons might fall out.
  11. Back Case: 手順 11、 3の画像 1 Back Case: 手順 11、 3の画像 2 Back Case: 手順 11、 3の画像 3
    • Orient the camera to the LCD screen side that is now wedged open.
    • Locate the white ribbon cable and pull out from motherboard.
    • Locate the brown ribbon cable and pull out from motherboard.
終わりに
作成者
3人の作成者と共同で作成されました。
Larissa Knight
メンバー登録日: 03/21/16
549 ポイント
5のガイドは作成済み
チーム
Clemson, Team 7-2, Benson Spring 2016 Clemson, Team 7-2, Benson Spring 2016人のメンバー
CLEM-BENSON-S16S7G2
4 メンバー
16のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 18
今までの合計 702
