メインコンテンツにスキップ
Babyliss Ionic SL hairdryer power switch Replacement
必要な工具と部品
    • remove two special head screws from device handle. Special tool required.
    • carefully separate the two plastic parts. You might have to pry them open on both sides of the top part.
    • mark all cables for later reference.
    • ATTENTION: there is a capacitator/condensator close by, better to remove it to prevent contact with the hot solder iron.
    • Desolder switch prior to removing from casing.
    • carefully push switch from inside out.
    • You might have to use a pair of pliers and some force to release the switch from plastic casing.
    • CTR-1215-y from XXX
    • 7.5A 125 V or 15A 250V
    • thanks to your labels you know which cable goes where.
    • push the two plastic parts together
    • tighten the screws.
    • Congratulations, you are done!
ゴール
作成者
2人の作成者と共同で作成されました。
JoeMoe
メンバー登録日: 09/09/21
145 ポイント
1ガイドが承認済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 4
過去 7 日: 16
過去 30 日: 41
今までの合計 1,009
