メインコンテンツにスキップ
必要な工具と部品
この分解は修理ガイドでは ありません。 お持ちのBaby Monitor を修理する際は、iFixitの修理ガイドをご利用ください。
  1. Baby Monitor  Teardown, Teardown: 手順 1、 3の画像 1 Baby Monitor  Teardown, Teardown: 手順 1、 3の画像 2 Baby Monitor  Teardown, Teardown: 手順 1、 3の画像 3
    この手順で使用する道具:
    Flathead 3/32" or 2.5 mm Screwdriver
    $5.49
    購入する
    • Here is the baby monitor in all its glory.
    • Start by turning the device speaker-side down.
    • Remove the flathead screw securing the battery cover using a flathead screwdriver.
    • Remove the battery cover after fully disengaging the screw.
  2. Baby Monitor  Teardown: 手順 2、 3の画像 1 Baby Monitor  Teardown: 手順 2、 3の画像 2 Baby Monitor  Teardown: 手順 2、 3の画像 3
    この手順で使用する道具:
    Phillips #1 Screwdriver
    $5.49
    購入する
    • Remove the batteries from the compartment.
    • Remove the five phillips screw holding the casing together using a phillips #1 screwdriver.
    • The fifth screw is hidden beneath the battery cover, toward the center of the monitor and is recessed deep into the casing.
  3. Baby Monitor  Teardown: 手順 3、 3の画像 1 Baby Monitor  Teardown: 手順 3、 3の画像 2 Baby Monitor  Teardown: 手順 3、 3の画像 3
    • CAUTION: Do not yank the casing apart!!!
    • Gently pry from the bottom and work a finger along the side and until monitor pops in half.
    • The speaker cabling is soldered to the main board and the speaker is stuck in the front casing with adhesive.
    • Lay the two halves as shown.
  4. Baby Monitor  Teardown: 手順 4、 1の画像 1
    • Remove the two screws securing the main board.
  5. Baby Monitor  Teardown: 手順 5、 2の画像 1 Baby Monitor  Teardown: 手順 5、 2の画像 2
    この手順で使用する道具:
    Spudger
    $3.99
    購入する
    • Pry lightly around the edge of the main board between the board and the casing to help free the board. Fingernails, a spudger, or plastic opening tools can be used for this task.
    • DO NOT TRY TO REMOVE THE MAIN BOARD COMPLETELY!!! There are soldered items that need to be dealt with. Follow along closely.
    • Gently, and I mean gently, pull up on the LED assembly to loosen the main board from the rear casing.
    • Any resistance should indicate that the board needs to be loosened from the casing, around the edges, more before proceeding.
  6. Baby Monitor  Teardown: 手順 6、 1の画像 1
    • PROCEED WITH CAUTION!!! The antenna cable and the battery contacts are soldered onto the board.
    • Your monitor should look like this, with a small gap between the main board and the rear casing.
    • The next step will merely free the volume control dial from the casing and NOT free the main board from the casing.
    • To remove the main board from the casing, you MUST desolder the antenna cable and two battery contacts from the board.
  7. Baby Monitor  Teardown: 手順 7、 3の画像 1 Baby Monitor  Teardown: 手順 7、 3の画像 2 Baby Monitor  Teardown: 手順 7、 3の画像 3
    • Create about a 30 degree angle between the rear casing and your workspace, lifting the casing by the top end. I used 3 decks of playing cards to prop up the casing from my workspace.
    • Lift the main board from the rear casing at the bottom, making sure the volume dial clears the screw retainer post. DO NOT COMPLETELY REMOVE MAIN BOARD!
    • Once free, set the main board back down on the casing.
    • You are now free to desolder any of the contacts that need repair. In my situation, I will be examining the volume dial and will not need to desolder.
    • Good luck!
作成者
2人の作成者と共同で作成されました。
Brady Cabe
2,743 ポイント
2のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 26
今までの合計 9,013
