メインコンテンツにスキップ
BaByliss-Expert Plus 2000 Hairdryer Thermal Fuse Replacement
必要な工具と部品
  1. BaByliss-Expert Plus 2000 Hairdryer Thermal Fuse  Replacement, Thermal Fuse: 手順 1、 2の画像 1 BaByliss-Expert Plus 2000 Hairdryer Thermal Fuse  Replacement, Thermal Fuse: 手順 1、 2の画像 2
    • Before disassembly, unplug the device.
    • Make sure the device was not on for the last 10 minutes, because it might still be hot.
    • Unscrew the two screws on the handle with the spanner screwdriver.
  2. BaByliss-Expert Plus 2000 Hairdryer Thermal Fuse  Replacement: 手順 2、 2の画像 1 BaByliss-Expert Plus 2000 Hairdryer Thermal Fuse  Replacement: 手順 2、 2の画像 2
    • Pull the case in opposite directions.
    • You might need a prying tool if the black components don't come out easily.
  3. BaByliss-Expert Plus 2000 Hairdryer Thermal Fuse  Replacement: 手順 3、 1の画像 1
    • Unscrew the remaining two screws inside the handle with the Phillips screwdriver.
  4. BaByliss-Expert Plus 2000 Hairdryer Thermal Fuse  Replacement: 手順 4、 3の画像 1 BaByliss-Expert Plus 2000 Hairdryer Thermal Fuse  Replacement: 手順 4、 3の画像 2 BaByliss-Expert Plus 2000 Hairdryer Thermal Fuse  Replacement: 手順 4、 3の画像 3
    • Push the inner components out of the handle.
  5. BaByliss-Expert Plus 2000 Hairdryer Thermal Fuse  Replacement: 手順 5、 2の画像 1 BaByliss-Expert Plus 2000 Hairdryer Thermal Fuse  Replacement: 手順 5、 2の画像 2
    • Locate the thermal fuse.
    • Test the thermal fuse for continuity using the multimeter.
    • Make sure the multimeter is set to 200 ACV and bring the probes toward thermal fuse.
    • The circuit is closed and properly functioning if the multimeter displays varying numbers.
    • The circuit is open if the multimeter displays non-varying numbers or no numbers at all.
  6. BaByliss-Expert Plus 2000 Hairdryer Thermal Fuse  Replacement: 手順 6、 1の画像 1
    • To replace the thermal fuse, use the prying tool to extract the object.
    • To remove it, wedge it back and forth until it comes free.
    • You don't need to take out the gold piece under the thermal fuse.
  7. BaByliss-Expert Plus 2000 Hairdryer Thermal Fuse  Replacement: 手順 7、 1の画像 1
    • Replace the old thermal fuse by a new one.
終わりに
2 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
Tiago
メンバー登録日: 12/05/16
49 ポイント
1ガイドが承認済み
チーム
Delft University of Technology, Team 1-12, Flipsen Fall 2016 Delft University of Technology, Team 1-12, Flipsen Fall 2016人のメンバー
TUD-FLIPSEN-F16S1G12
2 メンバー
2のガイドは作成済み
2 件のコメント
Does anybody know what is the small silver cylinder next to the thermal fuse? It is inline with the neutral AC from the handle switch, looks like it could be a diode or possibly a resistor, though it really resembles nothing I have seen before. My inoperable unit shows no continuity through this device either direction, so I presume it is bad….but I have no idea what to replace it with!
Richard H - 返信
This is the thermostat, not the “thermal fuse’’ !!
ilko M - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 19
過去 30 日: 124
今までの合計 9,336
