はじめに
This guide will teach you how to open up a BaByliss i-Pro 45 to change its batteries.
3x AAA 1.2V batteries with U-lips are required to be soldered onto the motherboard.
Opening up the device is an ideal opportunity to thoroughly clean it. Under the head/blades, some hairs may be stuck.
必要な工具と部品
Remove the rubber plug hiding the screw
Remove the screw under the plug
Remove two screws below the blades with a long Philips screwdriver
open the plastic parts holding the circuit in place
start lifting from the tail
9 の人々がこのガイドを完成させました。
11 件のコメント
Personally, I have been using this hair clipper for many years and it works perfectly well. Today I have to replace the battery. Can anyone tell me what the battery model is and if I need to use a soldering iron to replace it?
It is mentioned above:
So yes, a soldering iron is required, and the battery must have lips (i.e. not the standard AAA batteries you can find in any shop).
Fuss -
