はじめに
This guide documents how to replace the 2 soldered NiMH AAA batteries in the BaByliss T86a trimmer.
The original batteries are 600mAh, I have chosen to replace them with ENELOOP ones because they keep their charge for a long time.
You’ll be searching for the version with U solder lips. The ones I got from a local site had EAN 8438493102642
必要な工具と部品
Before you start unsoldering, write the polarity down so there is no unpleasant mistake later on!!!
There is plenty of solder, heat up one side and gently pull out the solder lip by pulling the battery. Then do the same thing at the other side.
Make sure to keep the holes open so we can insert the new ones later on
Now for the reassembly: just reverse the steps and pay attention to this:
First screw in the motor again
Remove the tape that shields the contacts
Align the PCB properly before clicking it in
When inserting the PCB, pay attention to the LED so it is inserted into its hole or you will not be able to close the case properly
When the PCB is in, do a quick test to make sure it runs
When attaching the head part, make sure the white insert is mounted properly: two tiny holes go over two pins in the head so the screw holes align perfectly. Center the moving part of the insert and center the motor pin so they fit
ある他の人がこのガイドを完成しました。
コメント 1 件
Excellent guide! I thought I had to replace the batteries, but didn't even know the top clicked open… :p Cleaning that out + separating the blades (try to do that without removing the spring, its difficult to put back) and thoroughly cleaning + lubricating there was enough to make it run like new :)
