メインコンテンツにスキップ
BRCK v1 Motherboard Replacement
必要な工具と部品
  1. BRCK v1 Motherboard  Replacement, Antenna: 手順 1、 1の画像 1
    • Stand the device on its side so the antenna is sitting on the top.
  2. BRCK v1 Motherboard  Replacement: 手順 2、 2の画像 1 BRCK v1 Motherboard  Replacement: 手順 2、 2の画像 2
    この手順で使用する道具:
    • Use the tweezers to grip the neck of the antenna(the part closest to the device).
    • Use opposite hand to twist off the body of the antenna.
  3. BRCK v1 Motherboard  Replacement, Top Cover: 手順 3、 1の画像 1
    • Place the face of the device showing BRCK face up.
  4. BRCK v1 Motherboard  Replacement: 手順 4、 1の画像 1
    • Remove the four screws(4mm hex head) on the corners of the device with a Hex 2.0 Screwdriver.
  5. BRCK v1 Motherboard  Replacement: 手順 5、 1の画像 1
    • Remove the top cover.
  6. BRCK v1 Motherboard  Replacement, Modem: 手順 6、 1の画像 1
    • Cut the black zip tie holding the modem down.
    • Caution By cutting the zip tie, you void any manufacturer warranty you may have on the device.
  7. BRCK v1 Motherboard  Replacement: 手順 7、 1の画像 1
    • Remove the connection located on the edge of the modem.
  8. BRCK v1 Motherboard  Replacement: 手順 8、 2の画像 1 BRCK v1 Motherboard  Replacement: 手順 8、 2の画像 2
    • Slightly lift the modem to reveal the brown ribbon connector and metal connection plate, located on the bottom of the modem.
  9. BRCK v1 Motherboard  Replacement: 手順 9、 3の画像 1 BRCK v1 Motherboard  Replacement: 手順 9、 3の画像 2 BRCK v1 Motherboard  Replacement: 手順 9、 3の画像 3
    この手順で使用する道具:
    • Using your tweezers, gently push on the metal plate and slide it down toward the base of the modem to release the locking mechanism.
    • Lower the plate and gently pull the ribbon out of the face plate.
    • Caution Be extremely gentle while preforming this step. The ribbon is brittle and prone to breaking if bent too much. Make sure you go slowly so that you do not damage the device.
  10. BRCK v1 Motherboard  Replacement: 手順 10、 2の画像 1 BRCK v1 Motherboard  Replacement: 手順 10、 2の画像 2
    • Remove the modem from the device.
  11. BRCK v1 Motherboard  Replacement, Motherboard: 手順 11、 2の画像 1 BRCK v1 Motherboard  Replacement, Motherboard: 手順 11、 2の画像 2
    • Remove the nut and washer from the RF connector, located where the antenna was connected.
  12. BRCK v1 Motherboard  Replacement: 手順 12、 2の画像 1 BRCK v1 Motherboard  Replacement: 手順 12、 2の画像 2
    • Unplug the red, black, and yellow wire connection by lifting up.
  13. BRCK v1 Motherboard  Replacement: 手順 13、 3の画像 1 BRCK v1 Motherboard  Replacement: 手順 13、 3の画像 2 BRCK v1 Motherboard  Replacement: 手順 13、 3の画像 3
    この手順で使用する道具:
    • Carefully insert tweezers under the black tab, and lift to release the clip.
    • Slide the ribbon out from under the clip to free the motherboard.
  14. BRCK v1 Motherboard  Replacement: 手順 14、 1の画像 1
    • Remove outside rubber covers by lifting them out of place.
  15. BRCK v1 Motherboard  Replacement: 手順 15、 3の画像 1 BRCK v1 Motherboard  Replacement: 手順 15、 3の画像 2 BRCK v1 Motherboard  Replacement: 手順 15、 3の画像 3
    • Slowly lift the motherboard out from the device by lifting it from the end next to the ribbon connection.
    • Lift and pull out of place.
終わりに
作成者
4人の作成者と共同で作成されました。
Jeret Buerger
メンバー登録日: 04/01/15
501 ポイント
5のガイドは作成済み
チーム
Cal Poly, Team 12-3, Lancaster Spring 2015 Cal Poly, Team 12-3, Lancaster Spring 2015人のメンバー
CPSU-LANCASTER-S15S12G3
3 メンバー
14のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 7
今までの合計 327
