メインコンテンツにスキップ
BOSE SoundTouch 30 Motherboard Replacement
必要な工具と部品
  1. BOSE SoundTouch 30 Motherboard Replacement, Base Plate: 手順 1、 2の画像 1 BOSE SoundTouch 30 Motherboard Replacement, Base Plate: 手順 1、 2の画像 2
    • Remove the four 15.5 mm PH2 screws securing the base plate to the device.
  2. BOSE SoundTouch 30 Motherboard Replacement, Power Supply: 手順 2、 1の画像 1
    • Remove the six 15.5mm PH2 screws securing the grille and rear panel to the device.
  3. BOSE SoundTouch 30 Motherboard Replacement: 手順 3、 2の画像 1 BOSE SoundTouch 30 Motherboard Replacement: 手順 3、 2の画像 2
    • Remove the grille and rear panel by grabbing the corners and pulling upwards and outwards.
    • There is a small ribbon cable that connects the display assembly to the body of the device. Make sure to disconnect the cable before pulling the grille all the way off or else the cable could snap.
    Is there any way to replace or repair the display ribbon cable? I snapped it and now I have no display.
    Carol Rigdon - 返信
  4. BOSE SoundTouch 30 Motherboard Replacement: 手順 4、 1の画像 1
    • Remove all four 15.5 mm PH2 screws holding the power supply down.
    • The power supply is identified by a green board with a large metal covering.
    I can buy the parts with you guys.
    Jaime Ojeda - 返信
  5. BOSE SoundTouch 30 Motherboard Replacement: 手順 5、 2の画像 1 BOSE SoundTouch 30 Motherboard Replacement: 手順 5、 2の画像 2
    • Disconnect the three cables from the power supply by squeezing the white tabs if present and gently pulling.
    • Pick up the power supply and remove the fourth cable from the underside of the power supply.
    • Remove the power supply.
    actually there are four connections - one underneath at the top of the picture above
    Simon Ward - 返信
  6. BOSE SoundTouch 30 Motherboard Replacement, Motherboard: 手順 6、 3の画像 1 BOSE SoundTouch 30 Motherboard Replacement, Motherboard: 手順 6、 3の画像 2 BOSE SoundTouch 30 Motherboard Replacement, Motherboard: 手順 6、 3の画像 3
    • Remove the five 15.5 mm PH2 screws holding the motherboard down.
    • Remove the three cables from the side of the motherboard by squeezing the grey tabs if present and gently pulling.
    • Remove the motherboard.
    • The motherboard is identified as the smaller green board with an ethernet, USB Type A, and an auxiliary port.
    hello there,
    I need a replacement of my motherboard, where can I buy this item?
    Thank you..
    edgar - 返信
終わりに
5 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Brennen Irey
メンバー登録日: 04/18/18
1,197 ポイント
6のガイドは作成済み
チーム
Cal Poly, Team S16-G2, Livingston Spring 2018 Cal Poly, Team S16-G2, Livingston Spring 2018人のメンバー
CPSU-LIVINGSTON-S18S16G2
4 メンバー
7のガイドは作成済み
5 Guide Comments
Where do I can get the power supply?
Ulises Peña - 返信
where can i get the notherboard? 354437-0060
guillermo gibson - 返信
Please where can I get the motherboard
Marjorie Newell - 返信
Where can I get the motherboard?
Bryan Lozano - 返信
I am getting an error “Error code 0000. Contact Bose service” what do I do?
Ashley Murray - 返信
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 15
過去 30 日: 73
今までの合計 6,364
