メインコンテンツにスキップ
BMW M-Colored LED Front Kidney Grille Installation
必要な工具と部品
  1. BMW M-Colored LED Front Kidney Grille Installation, Prep Work: 手順 1、 1の画像 1
    • You will need to remove a couple of bolts on the front bumper before you can start removing the BMW factory kidney grille.
  2. BMW M-Colored LED Front Kidney Grille Installation, Taking out the factory kidney grille: 手順 2、 3の画像 1 BMW M-Colored LED Front Kidney Grille Installation, Taking out the factory kidney grille: 手順 2、 3の画像 2 BMW M-Colored LED Front Kidney Grille Installation, Taking out the factory kidney grille: 手順 2、 3の画像 3
    • When you have enough clearance space, you can wedge your hand in between the gap to pop out the stock kidney grille.
    • Keep maneuvering your hand in the space to ease the stock grille out.
  3. BMW M-Colored LED Front Kidney Grille Installation, Watch out for the clips: 手順 3、 1の画像 1
    • Detach the stock kidney grille from the clips holding it onto the BMW front bumper.
  4. BMW M-Colored LED Front Kidney Grille Installation, Starting the swap: 手順 4、 2の画像 1 BMW M-Colored LED Front Kidney Grille Installation, Starting the swap: 手順 4、 2の画像 2
    • Pull out the factory kidney grille.
  5. BMW M-Colored LED Front Kidney Grille Installation, Putting in the new LED kidney grille: 手順 5、 2の画像 1 BMW M-Colored LED Front Kidney Grille Installation, Putting in the new LED kidney grille: 手順 5、 2の画像 2
    • Use your hand to apply a bit of pressure to pop the new LED M-stripe kidney grille in place
    • Secure the new LED grille onto the clips.
    • Note: the M-Colored LED stripe is only on the right grille assembly.
    • Tap the wire to the ACC or other 12V power source.
    • Repeat on the other side.
  6. BMW M-Colored LED Front Kidney Grille Installation, Put everything back: 手順 6、 1の画像 1
    • Put the bolts back into the BMW front bumper.
    • Enjoy your new M-Colored BMW LED Illuminated kidney grille.
終わりに
You can see that you didn't need to be an advanced car installer to attempt this. This makes the installation great for beginners as well as seasoned car fans alike.
2 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
Eric Wu
メンバー登録日: 01/21/15
3,357 ポイント
23のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 16
過去 30 日: 68
今までの合計 9,990
