メインコンテンツにスキップ
BLU Studio 7.0 II Battery Replacement
必要な工具と部品
  1. BLU Studio 7.0 II Battery Replacement, Back Cover: 手順 1、 1の画像 1
    • Locate the seam between the black and silver pieces of the phone.
    • Insert a plastic opening tool into the seam and firmly pry the black back piece away from the silver front piece.
    • To create the initial separation for the plastic opening tool, you may need to use either a spudger or metal spudger. If you use a metal spudger, be aware this can damage your phone if you aren't careful.
  2. BLU Studio 7.0 II Battery Replacement: 手順 2、 1の画像 1
    • Work your way around the edge of phone, firmly prying the pieces apart.
  3. BLU Studio 7.0 II Battery Replacement: 手順 3、 2の画像 1 BLU Studio 7.0 II Battery Replacement: 手順 3、 2の画像 2
    • Once the back has been removed, you can snap the new one into place by pressing firmly around the edges with your fingers.
  4. BLU Studio 7.0 II Battery Replacement, Battery Connection: 手順 4、 2の画像 1 BLU Studio 7.0 II Battery Replacement, Battery Connection: 手順 4、 2の画像 2
    • Using the PH00 screw driver, remove the two 3mm screws.
    • These screws may be covered by small, round black stickers. Remove the stickers to continue.
    • Remove the metal clip that connects the battery ribbon to the motherboard by lifting up. Precision tweezers work best for this part.
    • Be sure to only grab the metal clip with the tweezers, not the connector underneath.
  5. BLU Studio 7.0 II Battery Replacement: 手順 5、 1の画像 1
    • Disconnect the battery connector using a plastic opening tool or the flat end of a spudger.
  6. BLU Studio 7.0 II Battery Replacement, Battery: 手順 6、 2の画像 1 BLU Studio 7.0 II Battery Replacement, Battery: 手順 6、 2の画像 2
    • Using the black spudger, carefully but firmly pry the battery out of the housing.
    • There are two strips of adhesive on the left and right sides of the battery securing it to the housing. You may need some force to pull the battery out.
終わりに
ある他の人がこのガイドを完成しました。
作成者
2人の作成者と共同で作成されました。
Abby
メンバー登録日: 05/14/16
852 ポイント
5のガイドは作成済み
チーム
Metro State, Team 1-2, Carpenter SU 2016 Metro State, Team 1-2, Carpenter SU 2016人のメンバー
MSU-CARPENTER-SU16S1G2
4 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 12
今までの合計 2,490
