はじめに
This guide will show you how to replace the speaker on this phone.
  1. Remove the back cover on the phone with the plastic opening tool.
    • Remove the back cover on the phone with the plastic opening tool.
  2. Remove battery with plastic opening tool.
    • Remove battery with plastic opening tool.
  3. On the bottom part of the back of the phone with a Phillips screwdriver #00 tool remove the 6 screws that hold the speaker in place.
    • On the bottom part of the back of the phone with a Phillips screwdriver #00 tool remove the 6 screws that hold the speaker in place.
  4. Free shipping on all orders over $100.00 or containing a Pro Tech Toolkit!
    当社のショップを閲覧する
    Ever fixed something? That’s Genius.
    Share your repair story with #ImAGenius
    We Are All Geniuses
  5. After removing screws gently pull off the speaker from the back of the phone.
    • After removing screws gently pull off the speaker from the back of the phone.
  6. Remove the speaker from the backing of the speaker holder.
    • Remove the speaker from the backing of the speaker holder.
  7. Replace the  old speaker with a new speaker. Put it back in where the old speaker was.
    • Replace the old speaker with a new speaker. Put it back in where the old speaker was.
  8. Insert the plastic backing of the speaker back in the phone.
    • Insert the plastic backing of the speaker back in the phone.
    • Put the six screws back in the backing of the phone to hold the plastic backing securely.
まとめ
2 の人々がこのガイドを完成させました。
Maria Juzaino
メンバー登録日: 2014年10月25日
499 ポイント
3のガイドは作成済み
チーム
Gateway, Team 1-3, Johnson Fall 2014 Gateway, Team 1-3, Johnson Fall 2014人のメンバー
GCC-JOHNSON-F14S1G3
3 メンバー
5のガイドは作成済み
Excellent instruction! Great pictures as well! Well done+!
Kelly - 返信
Can you upload a guide on how to replace this device's screen? Pretty much appreciated.
Moe Ojeda - 返信
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 1,521
