メインコンテンツにスキップ
BLU Studio 5.0 S II Screen Replacement
必要な工具と部品
  1. BLU Studio 5.0 S II Screen Replacement, Remove back cover: 手順 1、 1の画像 1
    • Remove the back cover of the phone with the plastic opening tool, or your fingers.
  2. BLU Studio 5.0 S II Screen Replacement, Remove battery: 手順 2、 1の画像 1
    • Remove the battery from the phone with the plastic opening tool, or your fingers.
  3. BLU Studio 5.0 S II Screen Replacement, Motherboard: 手順 3、 2の画像 1 BLU Studio 5.0 S II Screen Replacement, Motherboard: 手順 3、 2の画像 2
    • Remove the microSD and SIM card. Gently tug on the microSD and SIM card to slide them out of their insert.
  4. BLU Studio 5.0 S II Screen Replacement: 手順 4、 2の画像 1 BLU Studio 5.0 S II Screen Replacement: 手順 4、 2の画像 2
    • Locate the 5 black 3.5mm screws and the 1 3.5mm silver screw on the top back plate.
    • Remove the 6 3.5mm screws by using a Phillips #00 screwdriver.
  5. BLU Studio 5.0 S II Screen Replacement: 手順 5、 2の画像 1 BLU Studio 5.0 S II Screen Replacement: 手順 5、 2の画像 2
    • Remove the inner top back black plate.
  6. BLU Studio 5.0 S II Screen Replacement: 手順 6、 2の画像 1 BLU Studio 5.0 S II Screen Replacement: 手順 6、 2の画像 2
    • Locate the 2 black 3.5mm screws on the motherboard.
    • Remove the black 3.5 mm screws using a Phillips #00 screwdriver.
  7. BLU Studio 5.0 S II Screen Replacement: 手順 7、 3の画像 1 BLU Studio 5.0 S II Screen Replacement: 手順 7、 3の画像 2 BLU Studio 5.0 S II Screen Replacement: 手順 7、 3の画像 3
    この手順で使用する道具:
    購入する
    • Locate the 2 orange ribbons on opposite sides.
    • Carefully remove the two ribbon cables using tweezers.
    • Gently rock the cable back and forth equally from both sides to not damage the pins.
  8. BLU Studio 5.0 S II Screen Replacement: 手順 8、 2の画像 1 BLU Studio 5.0 S II Screen Replacement: 手順 8、 2の画像 2
    • Gently rock the plastic opening tool back and forth until the motherboard releases from the phone.
    • Adhesion, identified with red circles, bonds the motherboard to the chassis. This may require extra effort to lift off from back of phone.
  9. BLU Studio 5.0 S II Screen Replacement: 手順 9、 2の画像 1 BLU Studio 5.0 S II Screen Replacement: 手順 9、 2の画像 2
    • Follow the wire from the motherboard.
    • Remove the black lining covering the wire.
  10. BLU Studio 5.0 S II Screen Replacement: 手順 10、 2の画像 1 BLU Studio 5.0 S II Screen Replacement: 手順 10、 2の画像 2
    • Locate the 5 black screws on inner black lower plate.
  11. BLU Studio 5.0 S II Screen Replacement: 手順 11、 2の画像 1 BLU Studio 5.0 S II Screen Replacement: 手順 11、 2の画像 2
    • Remove the bottom inner back plate.
  12. BLU Studio 5.0 S II Screen Replacement: 手順 12、 2の画像 1 BLU Studio 5.0 S II Screen Replacement: 手順 12、 2の画像 2
    • Holding the cable with the removal tool, gently pull in the direction of the cable to remove the connector from its socket.
  13. BLU Studio 5.0 S II Screen Replacement: 手順 13、 1の画像 1
    • Remove the whole motherboard.
    • The Motherboard contains the headphone jack and the power button.
  14. BLU Studio 5.0 S II Screen Replacement, Screen: 手順 14、 2の画像 1 BLU Studio 5.0 S II Screen Replacement, Screen: 手順 14、 2の画像 2
    • Peel off the bottom back with finger or supdger.
    • CAUTION: Adhesive is attached to the bottom circuitboard. May require extra effort to remove.
終わりに
To reassemble your device, follow these instructions in reverse order with the screen replacement.
2 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Curt Collingwood
メンバー登録日: 03/01/17
261 ポイント
2のガイドは作成済み
チーム
IUPUI, Team S2-G3, Harley Spring 2017 IUPUI, Team S2-G3, Harley Spring 2017人のメンバー
IUPUI-HARLEY-S17S2G3
4 メンバー
3のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 11
今までの合計 784
