メインコンテンツにスキップ
BLU Studio 5.0 S II Motherboard Replacement
必要な工具と部品
  1. BLU Studio 5.0 S II Motherboard Replacement, Remove back cover: 手順 1、 1の画像 1
    • Remove the back cover of the phone with the plastic opening tool, or your fingers.
  2. BLU Studio 5.0 S II Motherboard Replacement, Remove battery: 手順 2、 1の画像 1
    • Remove the battery from the phone with the plastic opening tool, or your fingers.
  3. BLU Studio 5.0 S II Motherboard Replacement, Motherboard: 手順 3、 2の画像 1 BLU Studio 5.0 S II Motherboard Replacement, Motherboard: 手順 3、 2の画像 2
    • Remove the microSD and SIM card. Gently tug on the microSD and SIM card to slide them out of their insert.
  4. BLU Studio 5.0 S II Motherboard Replacement: 手順 4、 2の画像 1 BLU Studio 5.0 S II Motherboard Replacement: 手順 4、 2の画像 2
    • Locate the 5 black 3.5mm screws and the 1 3.5mm silver screw on the top back plate.
    • Remove the 6 3.5mm screws by using a Phillips #00 screwdriver.
  5. BLU Studio 5.0 S II Motherboard Replacement: 手順 5、 2の画像 1 BLU Studio 5.0 S II Motherboard Replacement: 手順 5、 2の画像 2
    • Remove the inner top back black plate.
  6. BLU Studio 5.0 S II Motherboard Replacement: 手順 6、 2の画像 1 BLU Studio 5.0 S II Motherboard Replacement: 手順 6、 2の画像 2
    • Locate the 2 black 3.5mm screws on the motherboard.
    • Remove the black 3.5 mm screws using a Phillips #00 screwdriver.
  7. BLU Studio 5.0 S II Motherboard Replacement: 手順 7、 3の画像 1 BLU Studio 5.0 S II Motherboard Replacement: 手順 7、 3の画像 2 BLU Studio 5.0 S II Motherboard Replacement: 手順 7、 3の画像 3
    この手順で使用する道具:
    購入する
    • Locate the 2 orange ribbons on opposite sides.
    • Carefully remove the two ribbon cables using tweezers.
    • Gently rock the cable back and forth equally from both sides to not damage the pins.
  8. BLU Studio 5.0 S II Motherboard Replacement: 手順 8、 2の画像 1 BLU Studio 5.0 S II Motherboard Replacement: 手順 8、 2の画像 2
    • Gently rock the plastic opening tool back and forth until the motherboard releases from the phone.
    • Adhesion, identified with red circles, bonds the motherboard to the chassis. This may require extra effort to lift off from back of phone.
  9. BLU Studio 5.0 S II Motherboard Replacement: 手順 9、 2の画像 1 BLU Studio 5.0 S II Motherboard Replacement: 手順 9、 2の画像 2
    • Follow the wire from the motherboard.
    • Remove the black lining covering the wire.
  10. BLU Studio 5.0 S II Motherboard Replacement: 手順 10、 2の画像 1 BLU Studio 5.0 S II Motherboard Replacement: 手順 10、 2の画像 2
    • Locate the 5 black screws on inner black lower plate.
  11. BLU Studio 5.0 S II Motherboard Replacement: 手順 11、 2の画像 1 BLU Studio 5.0 S II Motherboard Replacement: 手順 11、 2の画像 2
    • Remove the bottom inner back plate.
  12. BLU Studio 5.0 S II Motherboard Replacement: 手順 12、 2の画像 1 BLU Studio 5.0 S II Motherboard Replacement: 手順 12、 2の画像 2
    • Holding the cable with the removal tool, gently pull in the direction of the cable to remove the connector from its socket.
  13. BLU Studio 5.0 S II Motherboard Replacement: 手順 13、 1の画像 1
    • Remove the whole motherboard.
    • The Motherboard contains the headphone jack and the power button.
終わりに
To reassemble your device, follow these instructions in reverse order with the new motherboard.
ある他の人がこのガイドを完成しました。
作成者
5人の作成者と共同で作成されました。
Aaron Isaacs
メンバー登録日: 03/01/17
107 ポイント
1ガイドが承認済み
チーム
IUPUI, Team S2-G3, Harley Spring 2017 IUPUI, Team S2-G3, Harley Spring 2017人のメンバー
IUPUI-HARLEY-S17S2G3
4 メンバー
3のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 12
今までの合計 478
