はじめに
This guide will show you a step by step guide on how to replace a camera on the BLU Studio 5.0 S II.
  1. Remove the back cover of phone with the plastic opening tool.
    • Remove the back cover of phone with the plastic opening tool.
  2. Remove the battery with the plastic opening tool.
    • Remove the battery with the plastic opening tool.
  3. Use the Philips #00 screwdriver to remove the nine screws that the top back part of the phone has.
    • Use the Philips #00 screwdriver to remove the nine screws that the top back part of the phone has.
  4. Free shipping on all orders over $100.00 or containing a Pro Tech Toolkit!
    当社のショップを閲覧する
    Ever fixed something? That’s Genius.
    Share your repair story with #ImAGenius
    We Are All Geniuses
  5. Once you take off the screws off the phone remove the plastic backing .
    • Once you take off the screws off the phone remove the plastic backing .
  6. Remove the ribbon cable carefully on all four sides of the motherboard of the phone. Remove the ribbon cable carefully on all four sides of the motherboard of the phone.
    • Remove the ribbon cable carefully on all four sides of the motherboard of the phone.
  7. Take off the four interior screws that are on the motherboard of the phone.
    • Take off the four interior screws that are on the motherboard of the phone.
  8. Remove the ribbon cable next to the camera carefully.
    • Remove the ribbon cable next to the camera carefully.
  9. Remove the motherboard of the phone and replace camera.
    • Remove the motherboard of the phone and replace camera.
まとめ
Maria Juzaino
メンバー登録日: 2014年10月25日
499 ポイント
3のガイドは作成済み
チーム
Gateway, Team 1-3, Johnson Fall 2014 Gateway, Team 1-3, Johnson Fall 2014人のメンバー
GCC-JOHNSON-F14S1G3
3 メンバー
5のガイドは作成済み
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 3
今までの合計 1,905
