はじめに
This guide will show you how to replace the volume button on your Blu Studio 5.0 II phone.
必要な工具と部品
Locate the four 3mm screws on each side of the back panel.
Use a Phillips #00 screwdriver to remove the eight screws.
Locate the volume button on the right side of the phone after removing back case.
Using a spudger carefully wedge between button and phone and carefully pry away from the phone.
Once removed the yellow buttons will be visible.
2 の人々がこのガイドを完成させました。
