メインコンテンツにスキップ
はじめに
Use this guide in order to successfully remove and replace the rear-facing camera on your BLU Studio 5.0 II phone.
パーツ
パーツは指定されていません。
  1. BLU Studio 5.0 II Rear Camera Replacement, Battery: 手順 1、 1の画像 1
    • Turn off your phone before disassembling the device.
    • Locate the small opening on the bottom corner of the back case.
  2. BLU Studio 5.0 II Rear Camera Replacement: 手順 2、 2の画像 1 BLU Studio 5.0 II Rear Camera Replacement: 手順 2、 2の画像 2
    • Use your finger to open the back case by slowly pulling it on the open slot.
    • Once the case is lifted on the corner, slide your finger along the edge of the phone to remove the rest of the case.
  3. BLU Studio 5.0 II Rear Camera Replacement: 手順 3、 3の画像 1 BLU Studio 5.0 II Rear Camera Replacement: 手順 3、 3の画像 2 BLU Studio 5.0 II Rear Camera Replacement: 手順 3、 3の画像 3
    • Locate the opening slot at the bottom of the battery.
    • Use your finger to lift the battery and remove it from the case.
  4. BLU Studio 5.0 II Rear Camera Replacement, Back Case: 手順 4、 1の画像 1
    • Locate the four 3mm screws on each side of the back panel.
    • Use a Phillips #00 screwdriver to remove the eight screws.
  5. BLU Studio 5.0 II Rear Camera Replacement: 手順 5、 3の画像 1 BLU Studio 5.0 II Rear Camera Replacement: 手順 5、 3の画像 2 BLU Studio 5.0 II Rear Camera Replacement: 手順 5、 3の画像 3
    • Carefully use a spudger to start opening the back case by inserting it between the black and blue lines on the side of the phone.
    • With the help of your fingers, continue to remove the back case by sliding it through the opening.
  6. BLU Studio 5.0 II Rear Camera Replacement, Rear Camera: 手順 6、 3の画像 1 BLU Studio 5.0 II Rear Camera Replacement, Rear Camera: 手順 6、 3の画像 2 BLU Studio 5.0 II Rear Camera Replacement, Rear Camera: 手順 6、 3の画像 3
    • Locate the camera, which is centered on the upper part of the motherboard.
    • Use tweezers to lift the camera slowly.
    • Carefully pull the camera out of the motherboard.
終わりに
Ricardo Sarabia
メンバー登録日: 2016年02月09日
1,042 ポイント
6のガイドは作成済み
チーム
USF Tampa, Team 7-5, Cheng Spring 2016 USF Tampa, Team 7-5, Cheng Spring 2016人のメンバー
USFT-CHENG-S16S7G5
3 メンバー
7のガイドは作成済み
0 件のコメント
コメントを追加
統計データを表示:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 1
今までの合計 289
