はじめに
This guide will show you how to successfully remove the motherboard from your BLU Studio 5.0 II.
必要な工具と部品
Locate the four 3mm screws on each side of the back panel.
Use a Phillips #00 screwdriver to remove the eight screws.
Locate the following adhesive buttons on the right and left side of the motherboard. These are the volume and power buttons.
Use a spudger to carefully separate them from the circuit board.
2 の人々がこのガイドを完成させました。
