メインコンテンツにスキップ
BLU R2 Plus Fingerprint Sensor Replacement
必要な工具と部品
  1. BLU R2 Plus Fingerprint Sensor Replacement, Power Off: 手順 1、 1の画像 1
    • Be sure that your BLU R2 Plus is completely powered off and has less than 25% battery left. This will lower the chance of your battery catching fire and your logic board/motherboard shorting out.
  2. BLU R2 Plus Fingerprint Sensor Replacement, Releasing the Back Cover: 手順 2、 3の画像 1 BLU R2 Plus Fingerprint Sensor Replacement, Releasing the Back Cover: 手順 2、 3の画像 2 BLU R2 Plus Fingerprint Sensor Replacement, Releasing the Back Cover: 手順 2、 3の画像 3
    • Insert your pick in the top left-hand corner where the little indent is.
    • Slide the pick all the way around the phone until the back cover is loose and ready to be released.
  3. BLU R2 Plus Fingerprint Sensor Replacement, Remove Back Cover: 手順 3、 1の画像 1
    • Remove the Back Cover to gain access to sim card trays, the memory card slot, or just to replace it.
  4. BLU R2 Plus Fingerprint Sensor Replacement, Tape the sticker: 手順 4、 3の画像 1 BLU R2 Plus Fingerprint Sensor Replacement, Tape the sticker: 手順 4、 3の画像 2 BLU R2 Plus Fingerprint Sensor Replacement, Tape the sticker: 手順 4、 3の画像 3
    • Use a plastic opening pick to peel up the sticker from the arms of both the upper and lower plastic plates on both sides of the battery. This will reveal screws to both plates.
    • To hold back the sticker, use small bits of tape.
  5. BLU R2 Plus Fingerprint Sensor Replacement, Unscrew Upper Plastic Plate: 手順 5、 1の画像 1
    • Use a Phillips #00 screwdriver to unscrew the nine screws from the upper plastic plate.
  6. BLU R2 Plus Fingerprint Sensor Replacement, Upper Plate Removal: 手順 6、 3の画像 1 BLU R2 Plus Fingerprint Sensor Replacement, Upper Plate Removal: 手順 6、 3の画像 2 BLU R2 Plus Fingerprint Sensor Replacement, Upper Plate Removal: 手順 6、 3の画像 3
    • Using an opening pick to wedge under spaces around the upper plate, unclip the upper plate from the phone and slide it up and out.
  7. BLU R2 Plus Fingerprint Sensor Replacement, Fingerprint Sensor: 手順 7、 3の画像 1 BLU R2 Plus Fingerprint Sensor Replacement, Fingerprint Sensor: 手順 7、 3の画像 2 BLU R2 Plus Fingerprint Sensor Replacement, Fingerprint Sensor: 手順 7、 3の画像 3
    この手順で使用する道具:
    • Use tweezers to carefully pull up the fingerprint sensor from the upper plate.
終わりに
作成者
2人の作成者と共同で作成されました。
Derek Thomas
メンバー登録日: 09/02/21
778 ポイント
5のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 5
今までの合計 133
