はじめに
A faulty motherboard can render your smartphone inoperable. This guide demonstrates the steps required to replace the motherboard on a BLU Life XL smartphone.
必要な工具と部品
Turn the device off by holding down the power button for up to 5 seconds and then tapping the "Power off" button on the screen.
Remove the rear cover using your hands at the lip on the device back cover. No tools required.
Remove the battery by lifting the lower edge of the battery up first.
Firmly press the prying tool into the gap between the front glass and rear plate. This gap is located on all sides of the phone.
Run the prying tool around the entire phone separating the rear plate from the frame.
Remove the two 12x3mm screws using the Phillips #000 screwdriver.
Remove the ribbon cables.
ある他の人がこのガイドを完成しました。
1 Guide Comment
how i identified the components in this motherboard
