メインコンテンツにスキップ
BLU Life X8 Daughterboard Replacement
必要な工具と部品
  1. BLU Life X8 Daughterboard  Replacement, Battery: 手順 1、 2の画像 1 BLU Life X8 Daughterboard  Replacement, Battery: 手順 1、 2の画像 2
    • Flip the phone over so that the screen is facing down.
    • Slide the opening tool between the micro-USB port and the back cover.
    • Use the opening tool to create a gap.
  2. BLU Life X8 Daughterboard  Replacement: 手順 2、 1の画像 1
    • Use your thumb to pry off the back panel once the gap is large enough.
  3. BLU Life X8 Daughterboard  Replacement: 手順 3、 1の画像 1
    • Once the back panel is off, locate the indent at the bottom of the battery.
    • Use your thumb to slip the battery out of the case.
  4. BLU Life X8 Daughterboard  Replacement, Motherboard: 手順 4、 2の画像 1 BLU Life X8 Daughterboard  Replacement, Motherboard: 手順 4、 2の画像 2
    • Use the Phillips #00 bit to undo the nine 1.5mm screws from the back of the device.
  5. BLU Life X8 Daughterboard  Replacement: 手順 5、 1の画像 1
    • Wedge the opening tool into the seam of between the screen and the gray frame.
    • Run the opening tool along the seam to release the clips that hold the two pieces together.
    • You may need to use the opening picks to prevent the clips from re-engaging.
  6. BLU Life X8 Daughterboard  Replacement: 手順 6、 1の画像 1
    • Once all the clips have been released, lift the frame and set it aside.
  7. BLU Life X8 Daughterboard  Replacement: 手順 7、 2の画像 1 BLU Life X8 Daughterboard  Replacement: 手順 7、 2の画像 2
    • Use the Phillips #00 Phillips bit to undo the two 1.5mm screws from the motherboard.
  8. BLU Life X8 Daughterboard  Replacement: 手順 8、 3の画像 1 BLU Life X8 Daughterboard  Replacement: 手順 8、 3の画像 2 BLU Life X8 Daughterboard  Replacement: 手順 8、 3の画像 3
    この手順で使用する道具:
    • Use the tweezers to peel away the mesh tape and reveal the ribbon connectors.
    • Use the tweezers to lift the brown and black tabs to release the ribbon cables and unlock them.
  9. BLU Life X8 Daughterboard  Replacement: 手順 9、 1の画像 1
    • The ribbon cables should be free. Pull back on the ribbons to release them from their connectors.
  10. BLU Life X8 Daughterboard  Replacement: 手順 10、 1の画像 1
    • Slowly lift the vibration motor away from the frame and peel up the tape.
  11. BLU Life X8 Daughterboard  Replacement, Daughterboard: 手順 11、 1の画像 1
    • Use the plastic opening tool to pry off the plastic guard covering the daughterboard and USB port.
  12. BLU Life X8 Daughterboard  Replacement: 手順 12、 1の画像 1
    この手順で使用する道具:
    • Remove the transparent tape covering one of the ribbon connectors using the tweezers.
  13. BLU Life X8 Daughterboard  Replacement: 手順 13、 3の画像 1 BLU Life X8 Daughterboard  Replacement: 手順 13、 3の画像 2 BLU Life X8 Daughterboard  Replacement: 手順 13、 3の画像 3
    • Use the tweezers to lift the black and beige tabs securing the ribbon cables.
    • Pull back on the ribbon cables to release them from their connectors.
  14. BLU Life X8 Daughterboard  Replacement: 手順 14、 1の画像 1
    • Lift the daughterboard from the frame using the plastic opening tool.
終わりに
作成者
4人の作成者と共同で作成されました。
Nicholas Harmon
メンバー登録日: 10/05/17
160 ポイント
1ガイドが承認済み
チーム
USF Tampa, Team S1-G2, Nance Fall 2017 USF Tampa, Team S1-G2, Nance Fall 2017人のメンバー
USFT-NANCE-F17S1G2
4 メンバー
6のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 7
今までの合計 328
