はじめに
The back camera may become damaged or scratched over time, causing poor quality pictures. This guide will explain how to access, remove, and replace your BLU Life X8 back camera.
必要な工具と部品
Flip the phone over so that the screen is facing down.
Slide the opening tool between the micro-USB port and the back cover.
Use the opening tool to create a gap.
Use the Phillips #00 (1.5mm) bit to undo the (9) screws from the back of the device.
ある他の人がこのガイドを完成しました。
