メインコンテンツにスキップ
BLU Dash Music 4.0 Headphone Jack Replacement
必要な工具と部品
  1. BLU Dash Music 4.0 Headphone Jack Replacement, Remove the Back Cover: 手順 1、 1の画像 1
    • Use the plastic opening tool or your fingernail to pry off the back cover.
  2. BLU Dash Music 4.0 Headphone Jack Replacement, Remove the Battery: 手順 2、 1の画像 1
    • Use the plastic opening tool or your fingernail to pry off the battery from the top right corner.
  3. BLU Dash Music 4.0 Headphone Jack Replacement, Remove the Screws: 手順 3、 2の画像 1 BLU Dash Music 4.0 Headphone Jack Replacement, Remove the Screws: 手順 3、 2の画像 2
    • Use a screwdriver to remove each of the four screws.
  4. BLU Dash Music 4.0 Headphone Jack Replacement, Remove the Inner Cover: 手順 4、 2の画像 1 BLU Dash Music 4.0 Headphone Jack Replacement, Remove the Inner Cover: 手順 4、 2の画像 2
    • Take the plastic opening tool and insert it in the crease between the front screen and the inner back cover.
    • Slide the plastic opening tool along the edge of the phone to pry the two covers apart.
  5. BLU Dash Music 4.0 Headphone Jack Replacement, Remove the Black Pad: 手順 5、 2の画像 1 BLU Dash Music 4.0 Headphone Jack Replacement, Remove the Black Pad: 手順 5、 2の画像 2
    • Insert the plastic opening tool between the black pad and the circuit board. Then gently pry off the black pad.
    • This will make the connections of the charging port more accessible.
  6. BLU Dash Music 4.0 Headphone Jack Replacement, Remove the Solder Connections: 手順 6、 2の画像 1 BLU Dash Music 4.0 Headphone Jack Replacement, Remove the Solder Connections: 手順 6、 2の画像 2
    • Using a soldering iron and a pair of pliers, melt the soldering connections around the headphone jack.
    • Quickly pull off the current headphone jack while the soldering connections are still soft.
  7. BLU Dash Music 4.0 Headphone Jack Replacement, Mount the New Headphone Jack: 手順 7、 1の画像 1
    • Mount the new headphone jack such that the prongs of the headphone jack line up with the soldering connections.
    • Using a soldering iron, solder the connections in place.
終わりに
作成者
2人の作成者と共同で作成されました。
Lioma Terrero Soto
メンバー登録日: 10/16/14
525 ポイント
5のガイドは作成済み
チーム
UMass Dartmouth, Team 6-8, Vijaybhaskar Fall 2014 UMass Dartmouth, Team 6-8, Vijaybhaskar Fall 2014人のメンバー
UMASSD-VIJAYBHASKAR-F14S6G8
4 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 7
過去 30 日: 10
今までの合計 411
