メインコンテンツにスキップ
修理を始めるには
修理する権利
パーツ&ツール
はじめに
This guide will take a bit of time so make sure your schedule is free before you attack this guide! If you have no soldering experience I suggest looking at Ifixits guide on soldering here.
  1. Turn off the phone first. Press the power button continuously for 2-3 seconds to shut down the phone.
    • Turn off the phone first. Press the power button continuously for 2-3 seconds to shut down the phone.
    • Using a plastic opening tool, pry open the back cover from the slit on the bottom right corner of the phone.
  2. Using a plastic opening tool or finger, pull out the battery.
    • Using a plastic opening tool or finger, pull out the battery.
  3. Remove the four 4.0mm Phillips #1 screws.
    • Remove the four 4.0mm Phillips #1 screws.
  4. Starting from a corner, separate the panel from the frame using the plastic opening tool. The volume button will pop out.
    • Starting from a corner, separate the panel from the frame using the plastic opening tool.
    • The volume button will pop out.
  5. Unscrew the 3.6mm Phillips #0 screw from the motherboard.
    • Unscrew the 3.6mm Phillips #0 screw from the motherboard.
  6. Using a spudger, lift the black ZIF connector at the top left corner of the phone.
    • Using a spudger, lift the black ZIF connector at the top left corner of the phone.
  7. Pull the ribbon cable out of the ZIF connector.
    • Pull the ribbon cable out of the ZIF connector.
  8. When the ribbon cable is removed from the ZIF connector, peel off the power sticky button using a plastic opening tool.
    • When the ribbon cable is removed from the ZIF connector, peel off the power sticky button using a plastic opening tool.
  9. Peel off the volume sticky button.
    • Peel off the volume sticky button.
  10. Separate the screen cover from the motherboard using the plastic opening tool.
    • Separate the screen cover from the motherboard using the plastic opening tool.
    • Make sure that the LCD screen stays attached to the motherboard while doing this.
  11. The microphone is at the bottom left corner of the phone. Lift the microphone very carefully. Unsolder the two lower wires (one red wire and one black wire). If you don't feel comfortable with this step I recommend looking at Ifixit's solder guide here.
    • The microphone is at the bottom left corner of the phone.
    • Lift the microphone very carefully. Unsolder the two lower wires (one red wire and one black wire).
    • If you don't feel comfortable with this step I recommend looking at Ifixit's solder guide here.
    • Solder the new microphone in the same spot. The black wire will go in the left spot and the red wire in the right spot.
終わりに
2 の人々がこのガイドを完成させました。
Saravpreet singh
メンバー登録日: 2015年07月08日
179 ポイント
1ガイドが承認済み
チーム
UW Tacoma, Team 1-4, Liner SU 2015 UW Tacoma, Team 1-4, Liner SU 2015人のメンバー
UWT-LINER-SU15S1G4
4 メンバー
2のガイドは作成済み
0 件のコメント
コメントを追加
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 437
