メインコンテンツにスキップ
修理を始めるには
修理する権利
ストア
はじめに
Screens on these phones can crack easily, using this guide you can have a clean brand new slick look again! It is also a nice way to get under the screen and remove dust particles.
  1. Turn off the phone first. Press the power button continuously for 2-3 seconds to shut down the phone.
    • Turn off the phone first. Press the power button continuously for 2-3 seconds to shut down the phone.
    • Using a plastic opening tool, pry open the back cover from the slit on the bottom right corner of the phone.
  2. Using a plastic opening tool or finger, pull out the battery.
    • Using a plastic opening tool or finger, pull out the battery.
  3. Remove the four 4.0mm Phillips #1 screws.
    • Remove the four 4.0mm Phillips #1 screws.
  4. Starting from a corner, separate the panel from the frame using the plastic opening tool.
    • Starting from a corner, separate the panel from the frame using the plastic opening tool.
    • The volume button will pop out.
  5. 今あるものを使い続けましょう
    オールインワインキットで安く修理して、節約しましょう。
    iPhone 修理キットを見る
    今あるものを使い続けましょう
    iPhone 修理キットを見る
  6. Unscrew the 3.6mm Phillips #0 screw from the motherboard.
    • Unscrew the 3.6mm Phillips #0 screw from the motherboard.
  7. Using a spudger, lift the black ZIF connector at the top left corner of the phone.
    • Using a spudger, lift the black ZIF connector at the top left corner of the phone.
  8. Pull the ribbon cable out of the ZIF connector.
    • Pull the ribbon cable out of the ZIF connector.
  9. When the ribbon cable is removed from the ZIF connector, peel off the power, sticky button using a plastic opening tool.
    • When the ribbon cable is removed from the ZIF connector, peel off the power, sticky button using a plastic opening tool.
  10. Peel off the volume sticky button.
    • Peel off the volume sticky button.
  11. Separate the screen cover from the motherboard using the plastic opening tool. And don't forget that your phone can mess up if u separate the motherboard from the screen cover Make sure that the LCD screen stays attached to the motherboard while doing this.
    • Separate the screen cover from the motherboard using the plastic opening tool. And don't forget that your phone can mess up if u separate the motherboard from the screen cover
    • Make sure that the LCD screen stays attached to the motherboard while doing this.
終わりに
5 の人々がこのガイドを完成させました。
Nathanael
メンバー登録日: 2015年07月23日
233 ポイント
1ガイドが承認済み
0 件のコメント
コメントを追加
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 1,116
