はじめに
A hands on guide to replacing the touch screen on the Blu Dash 3.5. This guide will detail the steps necessary to remove and replace the touch screen.
必要な工具と部品
Start by locating the slot on the lower right corner of the device.
Insert the opening tool into the slot.
Pry the back cover off. Once the corner is off, continue around the perimeter of the phone pulling the back off with your fingers.
Use the 000 Phillips screwdriver to remove the four 4.5 mm screws from the corners of the interior back panel.
Use the opening tool to pry open the plastic back panel to expose the motherboard.
Use tweezers to lift the tab where the cable is connected.
Use the opening tool to pry the motherboard from the front face plate.
ある他の人がこのガイドを完成しました。
