メインコンテンツにスキップ
BEM Mojo 2 Speaker Battery Replacement
必要な工具と部品
  1. BEM Mojo 2 Speaker Battery Replacement, Speaker Battery: 手順 1、 1の画像 1
    • Pull back the rubber corners to uncover the bottom screws.
    • Continue this process for all four 10 mm screws.
  2. BEM Mojo 2 Speaker Battery Replacement: 手順 2、 1の画像 1
    • Use the J0 screwdriver to remove all four 10mm screws from the bottom of the speaker.
    • Caution: It is important when using the screwdriver to not use excessive force as this may strip the screw and can damage the speaker itself.
  3. BEM Mojo 2 Speaker Battery Replacement: 手順 3、 1の画像 1
    • Remove the bottom cover of the speaker.
    • Caution: Be careful when removing the bottom cover of the speaker as there are wires that connect to the speaker itself that become exposed upon base removal.
    • Remove all of the wires from the speakers internal chip, utilizing the tweezers.
    • Caution: Be careful not to damage the chip.
  4. BEM Mojo 2 Speaker Battery Replacement: 手順 4、 1の画像 1
    • Remove the speakers battery from its metal base, utilizing the plastic opening tool.
  5. BEM Mojo 2 Speaker Battery Replacement: 手順 5、 1の画像 1
    • Remove the wires from the speakers battery using the tweezers or by gently removing them by lightly pinching.
終わりに
作成者
3人の作成者と共同で作成されました。
Rachel Iacoboni
メンバー登録日: 01/30/18
618 ポイント
5のガイドは作成済み
チーム
Baylor, Team S1-G1, Johnson Spring 2018 Baylor, Team S1-G1, Johnson Spring 2018人のメンバー
BU-JOHNSON-S18S1G1
3 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 8
今までの合計 432
