はじめに
This guide will demonstrate the replacement of the internal Wi-Fi antenna, which is important for connecting your Azpen A720 tablet to Wi-Fi. This replacement may be necessary if you are having issues connecting to Wi-Fi.
This replacement is relatively simple. All you will need is a soldering iron and solder, a magnetic project mat, a Phillips #00 screwdriver, and an iFixit opening tool.
必要な工具と部品
Use a Phillips #00 screwdriver to remove the two 4mm screws found on the top edge of the tablet near the power button.
Locate the gray cord attached to the motherboard and the battery. This is the wifi antenna.
