メインコンテンツにスキップ
Axess TA2513-10WT Speaker Replacement
必要な工具と部品
  1. Axess TA2513-10WT Speaker Replacement, Back Cover: 手順 1、 1の画像 1
    • Lay the tablet down on a flat surface with the screen facing up, and the external camera facing upwards and closest to you.
  2. Axess TA2513-10WT Speaker Replacement: 手順 2、 3の画像 1 Axess TA2513-10WT Speaker Replacement: 手順 2、 3の画像 2 Axess TA2513-10WT Speaker Replacement: 手順 2、 3の画像 3
    • Insert the plastic opening tool in the space between the screen and the back cover above the volume buttons.
    • Slide the plastic opening tool gently along the sides.
    • If a small gap is not created between the screen and the back cover, pry gently upward at each of these latching points.
  3. Axess TA2513-10WT Speaker Replacement: 手順 3、 1の画像 1
    • Place the spudger in an open space to keep the back case from shutting while you continue to slide the opening tool.
  4. Axess TA2513-10WT Speaker Replacement: 手順 4、 1の画像 1
    • Remove the back cover with your hands once all points have been unlatched. It should separate completely from the screen that contains the battery and chip components.
  5. Axess TA2513-10WT Speaker Replacement, Speaker: 手順 5、 1の画像 1
    • Remove tape attached to black and red speaker wires.
  6. Axess TA2513-10WT Speaker Replacement: 手順 6、 1の画像 1
    • Identify the four speaker nodes.
    • From left to right the nodes are "SPKP1", "SPKN1", "LN", and "LP"
  7. Axess TA2513-10WT Speaker Replacement: 手順 7、 1の画像 1
    この手順で使用する道具:
    購入する
    • Place the soldering tool on the speaker node labeled "SPKP1" and quickly remove the red wire with tweezers.
  8. Axess TA2513-10WT Speaker Replacement: 手順 8、 1の画像 1
    • Place the soldering tool on the speaker node labeled "SPKN1" and quickly remove the black wire with tweezers.
  9. Axess TA2513-10WT Speaker Replacement: 手順 9、 1の画像 1
    • Place the soldering tool on the speaker node labeled "LP" and quickly remove the black wire with the tweezers.
  10. Axess TA2513-10WT Speaker Replacement: 手順 10、 1の画像 1
    • Place the soldering tool on the speaker node labeled "LN" and quickly remove the red wire with tweezers.
終わりに
作成者
8人の作成者と共同で作成されました。
Steven Kavanagh
メンバー登録日: 03/24/15
301 ポイント
3のガイドは作成済み
チーム
Baylor, Team 6-3, Shaver Spring 2015 Baylor, Team 6-3, Shaver Spring 2015人のメンバー
BU-SHAVER-S15S6G3
3 メンバー
10のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 5
今までの合計 304
